Figure this out! -- ????
Okay I am thinking too much, and I am confusing myself......I have a 92 CX Hatch. The stock tire size is 165/70-13. I am putting a 16" rota circuit 8 on and tirerack says that for a 16" rim a 205/40-16 is the right size.....BUT......I have a SiR2 (b16a) swap. So I was thinking.....okay, the VSS in that is for a 94 del sol (DOHC VTEC). The del sol stock tire size is 195/60-14. For the del sol, tirerack says that 205/45-16 is the correct size for the car.....
I am trying to figure out which is correct....I want my speed to be correct and my miles to count correctly. I THINK that the 205/45-16 is right......but I am confusing myself. Anyone know for sure???
Thanks,
Dustin
Thanks,
Dustin
205/45R16 0.05 Inches taller than stock tire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">SELECTED TIRE SIZE:205/45R16
DIAMETER: 23.3" SECTION WIDTH: 8.1" SIDEWALL HEIGHT: 3.6"
MINIMUM RIM WIDTH: 6.5" MAXIMUM RIM WIDTH: 7.5"
REVOLUTIONS PER MILE: 867
IF YOU TRAVELED 60 MPH WITH THIS TIRE INSTALLED ON YOUR VEHICLE
YOUR SPEEDOMETER WOULD READ 59.9 MPH </TD></TR></TABLE>
Okay so I was right......the del sol is the "correct" car to look for on tirerack......and the 205/45R16 is the one I need. ****........anyone looking for some nitto 205/40-16 tires.......
Do you think the tiny difference will cause that much trouble??? Will I be okay with a 40 instead of 45 until I burn through these tires......?????? Any suggestions?
man....everyone seems to use 45's on civic's and del sol's and no prob's whatsoever.....maybe even better cause you protect your rims better and get a smoother ride......i'd go for the 45's
but either way they'll be fine!!!!
techsynthesis
Mar 4, 2008 05:28 PM
ApolloSpeed
11
Aug 24, 2005 03:40 PM
