Am i wrong or right
Old Jan 7, 2004 | 06:21 AM
JAPCIVIC R's Avatar
Default Am i wrong or right
im having big problems with my car 94 civic ls/vtec. The thing is i just got it back on the road after 2 years of down time. Once driven for 5 miles oil started leaking from the front of the motor where the head and block mat up so i guess valve seals. so i take off my header and oil pours out of the ex. ports. So i replace the valve seals and know car still burns oil a little and there is oil in the #1 cyl so im thinking valve guids.
Old Jan 7, 2004 | 07:20 AM
doublejz's Avatar
Default Re: Am i wrong or right (JAPCIVIC R)
it could be headgasket not seated correctly, any white smoke, or loss of coolant?
Old Jan 7, 2004 | 08:35 AM
JAPCIVIC R's Avatar
Default Re: Am i wrong or right (doublejz)
the smoke is white but very very light but no loss of coolant. i do remember when i first started her up and drove around from setting up for 2 years it smoked like crazy, but after replacing the seal it was not as bad, if it is the head gasket a comp. test would be able to tell me, right
Old Jan 7, 2004 | 12:03 PM
thad
Guest
Posts: n/a
did you relocate all the dowels for the LS gasket?
i'd say just pull the head off , if you want to replace the guides and seals that would be the time, but i bet you'll stop leaking after it gets a new gasket and gets retorqued.
Old Jan 8, 2004 | 05:16 AM
JAPCIVIC R's Avatar
Default Re: Am i wrong or right (thad)
i've changed the seals but im not to sure how to change the guides.
FTNW
Aug 17, 2012 07:59 AM
DRoylflush
11
Apr 10, 2011 02:11 PM
2001tegy
Sep 12, 2009 01:00 PM
a3k
Jul 26, 2009 10:36 PM
EF9 JAMS!!!
Aug 7, 2006 05:18 PM
