Where is a stock ITR's whp supposed to peak?
Old Jan 7, 2004 | 01:33 AM
TypeR1558's Avatar
New User
Default Where is a stock ITR's whp supposed to peak?
Just had my car dynoed a few times....
The car made 165whp in nearly stock form, but it seemed to begin dipping at around 7600-7800 rpm. Is this the normal place for the power to begin to decline on a stock ITR? I always just wind it up to near redline.. but if theres nothing weird with this peak location... shouldn't i be shifting sooner ?
Thanks,
Jon
Old Jan 7, 2004 | 01:18 PM
TypeR1558's Avatar
New User
Default Re: Where is a stock ITR's whp supposed to peak? (TypeR1558)
^bump please^
I've been looking around, and the stock peak whp rpm seems to be 8000. I'm making 165whp at like 7600-7800, then i begin to dropoff. Any ideas?
A friend recommended an ecu.
Jon
Old Jan 7, 2004 | 01:22 PM
RGoose18's Avatar
Peak whp for a stock R is at 8000 rpms.
Old Jan 7, 2004 | 01:24 PM
Reid's Avatar
Global Moderator
Have you been keeping up with your regular maintenance items?
Old Jan 7, 2004 | 01:42 PM
ZygSpeed's Avatar
Default Re: Where is a stock ITR's whp supposed to peak? (Reid)
What are your mods?
Since you say it's mostly stock.
BTW -- 165 isn't bad.
Old Jan 7, 2004 | 05:48 PM
uncleben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR1558 &raquo;</TD></TR><TR><TD CLASS="quote">but if theres nothing weird with this peak location... shouldn't i be shifting sooner ? </TD></TR></TABLE>
the problem with shifting much sooner then redline is that you'll end up just out of VTEC in the next gear
Old Jan 7, 2004 | 05:57 PM
Eric R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR1558 &raquo;</TD></TR><TR><TD CLASS="quote">Just had my car dynoed a few times....
Thanks,
Jon</TD></TR></TABLE>
Have you done some regular tune-up on your car lately? For example, adjust the valves, check timing up, fuel pressure, spark plugs, etc.
The peak power should be around the 8,000 - 8,200 rpm area on a stock R motor.
Old Jan 7, 2004 | 06:15 PM
Utilitarian's Avatar
All the dyno plots I've seen on here drop after 8K. You must have pretty low mileage to be cranking 165.
Old Jan 7, 2004 | 06:31 PM
Austin's Avatar
Clean your AEM filter.
Old Jan 7, 2004 | 06:34 PM
JjuuN R's Avatar
speaking of cleaning the filter
Old Jan 9, 2004 | 02:21 AM
TypeR1558's Avatar
New User
Default Re: (JUN.R)
Austin,
You may have a good point.
However, others who mentioned valve adjustments, etc.. maint. may have a good point. I have never had a valve adjustment yet, since the mileage is so low. It is possible that is causing a low peak rpm?
As for the 165whp peak... yeh, I was pretty pleased with that too... but as for it starting to dip at a lower than 8k rpm... not too sure about that. I'll try cleaning the filter and taking it from there......
Jon
Old Jan 9, 2004 | 04:22 AM
Jon D's Avatar
Literature (Type R brochures) say max peak is (8100).
Old Jan 9, 2004 | 05:35 AM
iperez's Avatar
Don't feel too bad, my "almost stock" 2001 ITR made 160whp (I forget what the RPMs were). I had a Comptech Icebox, Spoon 2-ply head gasket, and AEM pulleys.
Old Jan 9, 2004 | 07:25 AM
itr 00 0108's Avatar
You want to land where max torque begins, not max horsepower....if you land too low in the RPMs, you waste time climbing back...if you land after, it's a waste....
Torque is what you want to concentrate on...torque.
Old Jan 9, 2004 | 08:45 PM
blackntegra's Avatar
my jdm I/H/E ITR peaked at 8400
Old Jan 9, 2004 | 11:37 PM
Downey's Avatar
Default Re: (blackntegra)
wait a second.. you want your cars whp to peak later? i dont understand that. wouldnt you want to get to that 165whp as quick as you can? i would rather have 165 @ 7500 than 165 @ 8000.
im sure theres no dramitic dip after the peak. rev it out to 8600. ur probably still making a good 158-160 up there
ThA IntegrA HI
Jun 21, 2008 09:42 AM
wlee112
Jul 17, 2007 07:14 PM
VTECcnIT
Oct 30, 2005 01:44 AM
Gaylorde
Jul 8, 2005 11:47 AM
PreludeK
Jun 8, 2003 06:23 PM
