H22a Full Rebuild
Hey guys its finally time to do the rebuild for the turbo kit.
Will be getting:
-Arias forged 9.0:1comp
-eagle h-beam rods with arp 2000's or new age bolts?
-iron sleeves
-garrett 770hp turbo
-balanced rods, pistons, crank ect.
-standard head
-mircotech standalone ecu
Wat i want to know is that should i linish the crank?
Wat about my oil pump? should i bump up the pressure relief valve?
Wat bearings should i be looking to replace?
Wat head gasket? copper or one of those new cometic 3 layer ones?
Wat sise injectors?
Wat about a block brace?
Wat about arp head stud and main studs?
These are just the things that i can remember off the top of my head. I'd appreciate any other suggestions but keeping in mind that i'm not rich and cannot afford top of the line parts. I just want this engine to run safely to handle about 16psi (unless recommended higher?)
Thanks!!!
Will be getting:
-iron sleeves
-standard head
Wat sise injectors?
Thanks!!!
u should get the crank polished, it only cost like 35 bucks
def get a new oil pump while u are building, jsut bought mine and they run 220ish from honda
i was going to get honda bearings, they wouldh have ran around 250, but got acl's istead
not sure for boost but id get an oem head gasket
since its sleeved...u wont need the block brace..hope this helped a little
my guess is that a block brace is the same as a block guard, and dpepending on what year car you have the h22 is going to be a closed deck motor anyway, so you cannot use a block guard
B18Sleeper
Sep 21, 2008 02:32 PM
Sh4rky
May 13, 2002 10:12 AM
