starting car in winter
Old Jan 7, 2004 | 12:09 AM
JDMlyfestyle's Avatar
Default starting car in winter
Ok i just and tried starting my car its like -4 out now and it just like putted and i had to give it gas to keep it running is this normal? just wondering i got about a 1/4 of a tank of gas in it not sure if the gas froze or what?
Old Jan 7, 2004 | 02:47 AM
ne1????
Old Jan 7, 2004 | 02:52 AM
Jimmy's Avatar
Global Moderator
just let it warm up..its common sense
Old Jan 7, 2004 | 03:09 AM
JMod's Avatar
Default Re: (USDMDC2)
I'm pretty sure gas doesn't freeze.
Old Jan 7, 2004 | 03:33 AM
JimmyAtlantis's Avatar
Default Re: (BucsJosh)
I'm in Western NY (state...not the city) and it was like -14 last night. My car cranked hard (with less gas than you have), but it started after turning about 5 times. I didn't have to give it any gas or anything though. Maybe you're running lean? I dunno...GL
Old Jan 7, 2004 | 12:48 PM
I waited til this morning to start the car. its warmer out about 12 above. and it still wouldnt start. so i got some HEET gas antifreeze and 4 gallons of 95. and it still wouldnt start. and i drove the car just fine yesterday. any suggestions?
Old Jan 7, 2004 | 01:09 PM
monicle's Avatar
Default Re: (JDMlifestyle)
does it crank and crank and just not start?
Old Jan 7, 2004 | 01:10 PM
Yup. and it a couple times it tried to start and just went put put put. i tried to give it gas but i was to slow
Old Jan 7, 2004 | 02:50 PM
phillycx's Avatar
I'm no mechanical guru...but it could be the starter or alternator? I had a similar problem with a car I owned previously. Hope this helps...
Old Jan 7, 2004 | 02:53 PM
itr1235's Avatar
Default Re: (phillycx)
try starter fluid found at any gas station.
Old Jan 7, 2004 | 03:10 PM
misledyouth_is_back's Avatar
Default Re: (itr1235)
gas can't freeze but if there is moisture in your tank it will.
that is what heat is for
jesse
Old Jan 7, 2004 | 04:01 PM
Mr Boston's Avatar
Default Re: (misledyouth_is_back)
When you first start the car, Turn the key to the assessories position and leave it there for a couple of seconds and then crank it.
Old Jan 7, 2004 | 04:14 PM
quik1's Avatar
Default Re: (Ngo Power)
Gas can freeze. If you live in areas where it drops below freezing often most gas stations put antifreeze in the gas but if you live where it doesn't get to cold they don't.
Old Jan 7, 2004 | 04:16 PM
itsJDMyo's Avatar
Default Re: (quik1)
yea, it happens to my car sometimes...just keep on trying, and it will eventually work, atleast that's wat happens to me
Old Jan 7, 2004 | 04:32 PM
SIRIUS's Avatar
Default Re: (b00st)
Just a suggestion but get yourself some drygas. Pour in the full bottle w/ a full tank of gas. Also it's not a good idea to run the gas tank low when it gets that cold as condensation can form.
Old Jan 7, 2004 | 04:50 PM
SexySI's Avatar
Default Re: starting car in winter (JDMlifestyle)
When i first started my car today after it was sitting outside, it sputtered a little bit but just rev it up a little bit and let it warm up before driving it and youll be fine. Its about 15 degrees right now. Everything freezes up...power steering, Brakes, and clutch all feel like ****. VTEC didnt kick in until after about 20 minutes of driving. Definitely you should make a habit of waiting a few seconds with the key in the accessory position before starting, it helps.
Old Jan 7, 2004 | 06:04 PM
blazinb16's Avatar
Same thing happened to me last year after my swap...just let the fuel pump prime for a bit in the ACC position like everybody elts is sayin..
Old Jan 7, 2004 | 06:50 PM
zigs's Avatar
Default Re: starting car in winter (blazinb16)
Try replacing your spark plugs they foul out easily. Also if its not turning over charge the battery or have someone jump start it.
Old Jan 7, 2004 | 07:40 PM
ya i think im gonna replace my plugs tomorrow if all doesnt go well. thanks for the tips. more suggestions are welcomed. thanks guys
Old Jan 7, 2004 | 08:16 PM
supaZZZleepa's Avatar
it could also be the battery...depending how old/worn out your battery is...it wont or will be harder to start under harsh weather conditions (happened to me and when i got a new optium battery i didnt have that problem no more)
W95civicEXcoupe
25
Sep 29, 2014 05:07 AM
01_ITR
Apr 5, 2009 07:55 PM
menappi
Jun 21, 2006 04:01 PM
LvN
Jun 9, 2006 11:31 AM
MulletManRockStar
11
Sep 19, 2004 02:44 AM
