Type R oil pump vs. Gsr Oil Pump
Old Jan 6, 2004 | 11:02 PM
Cractos's Avatar
Default Type R oil pump vs. Gsr Oil Pump
Does the type R oil pump flow that much more then a gsr oil pump?
Old Jan 7, 2004 | 05:48 AM
AlphaMike's Avatar
Default Re: Type R oil pump vs. Gsr Oil Pump (Cractos)
type-r and obd2 GSR oil pumps are the same pump
Old Jan 7, 2004 | 11:53 PM
boredracer408's Avatar
Default Re: Type R oil pump vs. Gsr Oil Pump (AlphaMike)
Whats the difference between a 95 b16 oil pump to a 00 Type R oil pump?
Old Jan 8, 2004 | 12:16 AM
Cractos's Avatar
what are the pros and cons of buying a used type r oil pump...
Old Jan 10, 2004 | 11:29 AM
InitialDSR's Avatar
Default Re: (Cractos)
GS-R and Type Rs have the same damn oil pump. the Pros of the used oil pump..... cheaper den new. The COns.....might be bad ... oil gear warp... about to break........ so Fawk ... go out there and get your fawkin self a new oil pump for around 80-100 bucks... so being cheap and have some extra insurance
Old Jan 10, 2004 | 12:02 PM
B18CXr's Avatar
Default Re: Type R oil pump vs. Gsr Oil Pump (boredracer408)
the keyway on the crank is different on OBDII motors....
Old Jan 10, 2004 | 01:10 PM
ek9turbo's Avatar
i used the same type r oil pump that i was using in my all motor type r setup, now im using the same pump in my ls block " but there is only 2000 miles on the pump"
i have very good oil pressure, having no problems,but i still wont buy a used oil pump
all-mtr-teg
Aug 24, 2006 04:40 PM
s2kkid
Dec 20, 2004 05:01 AM
hontegra
Jan 13, 2004 04:03 PM
PROFILES2000
Feb 25, 2002 01:17 PM
