Steering problem with my EG sedan
Old Jan 6, 2004 | 10:19 PM
elmo908's Avatar
Default Steering problem with my EG sedan
whats up everyone, Im new here and this is my first post. I have an eg sedan and it was giving me steering problems lately, when i was coasting or on light throttle the steering wheel would jerk to the right. I turned the wheel at a stop and i heard two loud pops and the jerking thing never happened again. Now the problem is that when i turn left i hear a click click click that is directly related to the speed of the wheel rotation. Is my axle fucked up? or alignment or what? I guessed alignment because this is the first front wheel drive car I have had.
Old Jan 6, 2004 | 10:24 PM
JDMH22HATCH's Avatar
Default Re: Steering problem with my EG sedan (elmo908)
The clicking you are hearing when turning is probably your axle. The quick jerk to the right could have been a dip in the road, maybe alignment, dead cat you ran over, but just jack your car up and check the axles.
Old Jan 6, 2004 | 10:25 PM
Default Re: Steering problem with my EG sedan (JDMH22HATCH)
BTW -- Welcome to H-T
Old Jan 6, 2004 | 10:27 PM
elmo908's Avatar
thanks a lot man. Ive been meaning to do that but I have a broken down datsun in my garage right now. Ill check it out asap. How much whould a new axle cost btw?
Old Jan 6, 2004 | 10:28 PM
You can go to autozone and with the core replacement get an axle for $55 plus tax. Not too bad, plus it has a lifetime warranty.
Old Jan 6, 2004 | 10:55 PM
elmo908's Avatar
rad man thanks. Ill cruise up there just like in the commercials.
Old Jan 6, 2004 | 11:18 PM
liam821's Avatar
25 Year Member
Could be a few things.
1. wheel bearing bad. Easy to check, try to move the wheel back and forth. It shouldnt move at all. If there is play back and forth, the wheel bearing is bad.
2. Axle. Check the seals around the axle..if they are badly worn or ripped, the axle could be bad. Check for oil around the axles seals. Also make sure the axle nut is tight.
3. Steering rack loose. There is two or three bolts that hold the steering rack to the frame. On my car, the bolts came loose after around 200,000 miles and the whole steering rack was loose. So you would be going straight and all of a sudden the car would jerk. It was mad scary. Just tightened the bolts and that fixed that problem.
Good luck!
liam
ps welcome to honda-tech
Old Jan 7, 2004 | 02:18 PM
elmo908's Avatar
i think it is the steering rack thing because it stopped giving me a problem but weird sudden jerks is exactly what it would do. But it was only to the right.
Old Jan 8, 2004 | 06:08 PM
liam821's Avatar
25 Year Member
Default Re: (elmo908)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmo908 &raquo;</TD></TR><TR><TD CLASS="quote">i think it is the steering rack thing because it stopped giving me a problem but weird sudden jerks is exactly what it would do. But it was only to the right. </TD></TR></TABLE>
its easy to check..just make sure the bolts are tight.
liam
JapRat
Suspension & Brakes
May 27, 2010 09:58 PM
jpopson43
Apr 20, 2007 05:41 PM
ohsnapzafingcu
May 11, 2006 05:13 AM
erniecars
Jun 28, 2005 05:16 PM
CunninLynguist
May 7, 2003 11:54 AM
