89 crx si suspension (unfixable?)
I hit a curb awhile back dead on and pushed both front tires back. Attempting to fix the problem I replaced my lower control arms, struts, front crossmember, and radius rods. All these things helped the problem but did not fix it. My wheels are still pushed back. Is there anything else it could be besides the frame?
yeah well obviously if the tires are pushed back but how am i supposed to fix it somethig is obviously bent somewhere there is no camber or caster adjustment on crx's
on the front of the radius rods where they go thru the crossmember there are 2 rubber bushings - make sure that the thicker one is in the front (closest to nut) - if you get them reversed, it can push the wheels back
I'd wonder if you didnt warp your shock tower? Mind you the lca whouldnt bolt back in.
I'd check the mountin points for the parts your replaced and see if they are fubared.
May need to put the car on a frame straightner
try and see if you can see any visible metal strain.
If not, and everything looks normal, but the wheels are still pushed back, you might need to bring it to a frame shop and have them check specs on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan89crxsi »</TD></TR><TR><TD CLASS="quote">yeah well obviously if the tires are pushed back but how am i supposed to fix it somethig is obviously bent somewhere there is no camber or caster adjustment on crx's</TD></TR></TABLE>
I don't know why people say this. Where the UCAs connect to the body are slotted holes, you loosen the UCA anchor bolt nuts and move the strut and everything accordingly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">
I don't know why people say this. Where the UCAs connect to the body are slotted holes, you loosen the UCA anchor bolt nuts and move the strut and everything accordingly.</TD></TR></TABLE>
You sure about this? Neither my 90 hatch, 90 CRX nor 94 Teg have any "slotted" mounting holes for camber adjustment. The Helms doesn't show this either. Just curious, I might have wasted my money on a camber kit. I can see how this could work, but haven't seen it on any of my Hondas.
chris
chris
You have over 2,500 posts and you posted that?
You need to work on your car more often. Those holes aren't slotted.
I understand you are NOt saying they are slotted side to side, but rather slotted from towards the front of the car toward the back. No matter how you look at it, those holes aren't slotted... they're round.
they are definately not slotted because that would alow caster adjustment even if very little it would be considered an adjustment which there is none on the ef the only factory adjustment is toe and toe only, does anyone know approximately how much it costs to have a frame checked out and then how much it is to get it straightened if it indeed has to be done?
I am going to post the printout as soon as I finish the alignment on the taurus im going to put my car up on the rack I will post the readings
Here are the readings....caster is way bad! Pease help and like I said before I have replaced both lower control arms and the front most crossmember and radius rods since the accident
Left Front Right Front
Camber : -0.2' Camber : -0.9'
Caster : 0.7' Caster : 0.9'
Toe : 0.30' Toe : 0.00'
Specs
Camber : -1.0' - 1.0'
Caster : 2.0' - 4.0'
Toe : -0.06' - 0.06'
Specs
bump...my passanger wheel is pushed back too after hitting a curb...nothing looks bent on inspection...wheel shakes pretty bad now even after alignment.
you got any wheel shake dan?
a small amount unless i just cant really feel it because of becoming used to it heheh but really i need to get my car fixed it looks horrible not to mention its probably not good for alot of other things
Specs
Specs
