need wheel offset help!
Old Jan 6, 2004 | 06:28 PM
(JON)'s Avatar
Default need wheel offset help!
i have 16x7 wheels with a 32 offset. if i use a 205/45/16 tire and roll the fender lip will i have clearance problems. is there any way to have this set up work? any help or suggestions would be appreciated. thank you.
jon
Old Jan 6, 2004 | 06:35 PM
Pondus's Avatar
Default Re: need wheel offset help! (DaStyle)
If you have the wheels why not slap them on to see for yourself how they fit, my guess is it's gonna be tight, think you'll have to get your lips rolled.
I have used same size rims and tires, only difference is my rims are +45 and i get a fingertip ( not my thumb though ) between the tire sidewall and the fender lip.
Old Jan 6, 2004 | 06:49 PM
Utilitarian's Avatar
Stock suspension, right?
Old Jan 6, 2004 | 08:42 PM
Kicker773's Avatar
Default Re: need wheel offset help! (Stock97ITR#50)
that's with a 32 offset right?? hmm.. i dunno..
Old Jan 6, 2004 | 10:08 PM
(JON)'s Avatar
yeah stock usdm itr suspension
Old Jan 7, 2004 | 08:19 AM
(JON)'s Avatar
up please!
Old Jan 7, 2004 | 08:13 PM
(JON)'s Avatar
night time bump. any help is appreciated!
Old Jan 7, 2004 | 10:01 PM
gary201147's Avatar
I have +43 16x7 wheels on a stock suspension and same tire size and it doesnt rub at all. I dont think an extra cm offset will cause any rubbing either...
no rubbing even during autocross by the way
Old Jan 7, 2004 | 10:06 PM
Black R's Avatar
25 Year Member
.....should fit without rubbing - even at full lock (with stock its suspension).
Mount them and take pics!
Old Jan 8, 2004 | 05:07 AM
(JON)'s Avatar
Default Re: need wheel offset help! (Black R)
thanks for the input guys!
Old Jun 12, 2004 | 03:48 PM
sittin on GOLD's Avatar
Default Re: need wheel offset help! (gary201147)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gary201147 &raquo;</TD></TR><TR><TD CLASS="quote">I have +43 16x7 wheels on a stock suspension and same tire size and it doesnt rub at all. I dont think an extra cm offset will cause any rubbing either...
no rubbing even during autocross by the way</TD></TR></TABLE>
yea, that extra 10cm offset is a big difference. but, has anyone actually run this 32 offset on their itr? cuz i want to pick up some 16x7 32 offset wheels but i want to make sure everything is cool...even with rolling the fenders.
Old Aug 19, 2004 | 08:59 AM
allmotaR's Avatar
Default Re: need wheel offset help! (advertise)
can anyone verify this?...
Old Aug 19, 2004 | 10:58 AM
Ill's Avatar
Ill
Um, I think it's 10 * MM *, not cm. Not that much difference really.
Old Aug 19, 2004 | 11:03 AM
Default Re: need wheel offset help! (Ill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ill &raquo;</TD></TR><TR><TD CLASS="quote">Um, I think it's 10 * MM *, not cm. Not that much difference really.</TD></TR></TABLE>
oops i meant mm. sorry, but hell yea +10 is a big difference. as it shows difference between +35 and +45...
Old Aug 19, 2004 | 02:33 PM
Big Phat R's Avatar
Stock offset is +50
So you're out 18 mm per side (increase front track 36 mm or 3.6 cm)
FYI 18mm = just under 3/4"
With 205 section tire width - it'll be close
Slayerzero
Honda Civic (2006 - 2015)
Jun 25, 2011 08:33 AM
jeremy.
Jun 20, 2004 10:28 AM
t-blizzard
Jan 21, 2004 07:33 PM
JDM DC2 R
Jan 23, 2002 08:05 AM
