92-95 civic si to coupe rear discs Ebrake Q
Old Jan 6, 2004 | 06:20 PM
CivicSiRracer69's Avatar
Default 92-95 civic si to coupe rear discs Ebrake Q
Whats up guys Looks like I may be recieving a set of rear discs...the problem is that I have a 94 Coupe... and form what I read when I searched...is that you need a coupe E brake cable... Will a 94+ teg Coupe Cable work???
Old Jan 7, 2004 | 12:54 PM
Default Re: 92-95 civic si to coupe rear discs Ebrake Q (civiksiracer1)
ttt
Old Jan 7, 2004 | 12:56 PM
JDMH22HATCH's Avatar
Yes they will, but the cables from the SI should work too though. I'll double check though.
Old Jan 7, 2004 | 01:03 PM
Default Re: 92-95 civic si to coupe rear discs Ebrake Q (JDMH22HATCH)
k cool thanx man!
Old Jan 7, 2004 | 01:13 PM
TeamNextGenChris's Avatar
i THINK the hatch cables will be too short,although you may be able to route them differently to gain a little length-i'm sure the difference is small....i have 94+ Teg cables on my coupe.
chris
Old Jan 7, 2004 | 01:17 PM
Echo7847's Avatar
Default Re: 92-95 civic si to coupe rear discs Ebrake Q (TeamNextGenChris)
I used teg cables as well, and mine were a tad short, but if I got down there and tinkered around a bit I could prob fix it. I just routed the cables through normally and sip tied them to the undercarriage.
Old Jan 7, 2004 | 01:27 PM
Default Re: 92-95 civic si to coupe rear discs Ebrake Q (Echo7847)
ok so the Teg calbes work with some modding?! sweet!
Old Jan 7, 2004 | 02:50 PM
Beatkidd's Avatar
How much are 95 rear discs worth?
the full conversion?
Old Jan 7, 2004 | 03:03 PM
Default Re: 92-95 civic si to coupe rear discs Ebrake Q (Beatkidd)
200-300 im trading my Mint HX rims for them and 50 bucks
Darrell Woods
Sep 12, 2016 08:30 PM
angrysmileyface
Dec 12, 2011 10:23 PM
gsrguy94
Dec 6, 2007 02:58 AM
phyzJunkieCivic
11
Jun 11, 2007 02:04 PM
WHATS VTEC
Dec 30, 2002 04:34 PM
