headlight problem need help!
Old Jan 6, 2004 | 05:59 PM
CoolKat's Avatar
Default headlight problem need help!
tonight i put my stock lights back in and took out the HID's, now that i have taken teh HID's out.
both high beams work normally but only one normal driving light is on and the other is out. does anyone know the problem or had this problem?
i checked the fuses and everythig is good.
its a 95 honda civic cx hatch to let u guys know. if anyone can h elp that would be great
Old Jan 6, 2004 | 06:18 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: headlight problem need help! (CoolKat)
Try checking your relays underneath the hood....and if that is not the case, your headlight bulb might be shot. Just because your high beams come on doesn't mean the bulb is properly working
Old Jan 6, 2004 | 07:57 PM
ShakesTheKlown's Avatar
Sure you don't need new bulbs?
Old Jan 6, 2004 | 08:07 PM
tFUnK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoolKat &raquo;</TD></TR><TR><TD CLASS="quote">tonight i put my stock lights back in and took out the HID's, now that i have taken teh HID's out.
its a 95 honda civic cx hatch to let u guys know. if anyone can h elp that would be great</TD></TR></TABLE>
i dont know about the 95 gen but the 96-00 gen uses h4 and it's dual filament so probably one of the filaments is shot on the bulb. happened to me once after changing lightbulbs, the filament was shaking around in the glass.
Old Jan 6, 2004 | 08:30 PM
jdmgeorge's Avatar
Same thing happened to my car. I just had honda fix it. IF its not the bulb that is bad then it is most likely the harness that plugs into the back of the bulb, my harness went bad and honda installed a new one and a new bulb for like $25 for me.
Old Jan 6, 2004 | 09:45 PM
Ya@inlinePRO's Avatar
Default Re: headlight problem need help! (jdmgeorge)
just curious why did you take out the HID's?
Old Jan 10, 2004 | 08:26 PM
CoolKat's Avatar
Default Re: headlight problem need help! (kwik2nec)
thanks fellas, shot bulb. took out the hid so i could pass inspections. if anyone is interested in the HID let me know.
Old Feb 3, 2004 | 03:33 PM
freezerburnv2's Avatar
Selling HID kit eh? How much?
Cian Mcloughlin
Aug 13, 2012 12:06 PM
Digiti123
Aug 2, 2007 06:20 AM
CivicVelox17
Jan 2, 2007 10:11 PM
Weapon_R
Nov 12, 2004 07:29 PM
gsr-2nr
Jul 18, 2004 04:53 PM
