vaccum leak in brakes?
whenever i step on the brake pedal i hear a vaccum leak and the harder i step on it the louder it gets, and furthermore the power booster seems to work less and less the louder the leak gets. so when i step on the brake pedal really hard, it hardly works. i haven't had the time to look at it although im shure i could figure it out easily. but has anyone had this problem before, or know exactly where the leak is coming from? oh yea and the idle gets higher the harder i step on the brakes due to the vaccum leak. so anyone have any ideas?
Try this first ..pull off the master and make sure the gasket between the booster and the master is cool if that is ok ...You gots probs with the booster replace it
Gasket between the MC and bootser??
When I bought my MC and booster from the wreckers yard there was no gasket between the two. Is there really supposed to be one?
What does the gasket do just keep it air tight?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MTP04 »</TD></TR><TR><TD CLASS="quote">Gasket between the MC and bootser??
What does the gasket do just keep it air tight?</TD></TR></TABLE>
if there were no gasket, it would be leaking, thus a gasket would form to a shape so that there would be no leak. buy the gasket b4 ya crash the dam thing
Bipolarcivic
Sep 16, 2013 09:09 AM
zzsql
Nov 14, 2007 08:38 AM
srswarts3
19
Jul 4, 2005 07:27 PM
