Bad clutch makers
Old Jan 6, 2004 | 05:02 PM
98cwitr's Avatar
Default Bad clutch makers
well to make a long post short i was wondering what clutch makers to stay away from? Ive been looking at ACT, CM, and Exedy and also thought about sticking with the stock clutch. My stock clutch is about to take a **** so I need a new one. I really couldnt find any horror stories while using the search button, but the worst i could find is that some clutch required post-install adjusting (which i dont understand considering hydraulic trannies and all).
Old Jan 6, 2004 | 05:18 PM
Jowee's Avatar
Default Re: Bad clutch makers (98cwitr)
I've heard that ACT makes good clutches, but I know for sure they have a shitty warranty policy. https://honda-tech.com/zerothread?id=455382
Old Jan 6, 2004 | 05:21 PM
BudMan's Avatar
If I can install a CM stage 3+flywheel, with no tranny experience & drive the pisser out of it for 40,000 miles it must be good product!
Old Jan 6, 2004 | 05:40 PM
jaa1311's Avatar
Default Re: Bad clutch makers (BudMan)
same here
Old Jan 6, 2004 | 06:41 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan &raquo;</TD></TR><TR><TD CLASS="quote">If I can install a CM stage 3+flywheel, with no tranny experience & drive the pisser out of it for 40,000 miles it must be good product!</TD></TR></TABLE>
same here too...had a CM stage 3 in my car for a long time making a lot of power.finally got worn out after many miles-much longer than i expected...i've installed plenty of CM clutches and know many people that use them-never heard a complaint..i've also installed some ACT clutches,and honestly,i wasn't as impressed with them.on some boards the ACT products also seem to have a bad reputation.
i'd go with a CM product,if you even need an aftermarket clutch.with just bolt-ons you could get away with either a stock setup or a lower level CM product..
either way i'd suggest a billet flywheel-you'll love it!
chris
Old Jan 6, 2004 | 06:58 PM
ACTman's Avatar
Default Re: Bad clutch makers (ITR 98 1162)
If you have any questions about ACT, I am available by email or the HT forum. If you want the sales pitch, let me know. Otherwise, I will spare everyone the chatter.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard that ACT makes good clutches, but I know for sure they have a shitty warranty policy. https://honda-tech.com/zerothread?id=455382 </TD></TR></TABLE>
Old Jan 6, 2004 | 07:56 PM
JDM_JON's Avatar
Default Re: Bad clutch makers (ACTman)
ClutchMasters
Old Jan 6, 2004 | 08:06 PM
ArmyGreenITR's Avatar
Default Re: Bad clutch makers (JDM_JON)
Ive had a few friends have bad luck with ACT ive had good experince with CM an exeddy.
Old Jan 6, 2004 | 08:22 PM
danelot's Avatar
Do a search for exedy. Quite few people posted problems with this clutch. I drove someone else's ITR with one in it. I liked the feel of it but would be weary of longevity. My oem works fine for now
Old Jan 6, 2004 | 08:26 PM
Kicker773's Avatar
Default Re: Bad clutch makers (danelot)
i've heard clutchnet has bad clutches.. from an old post onthe forum
Old Jan 6, 2004 | 08:50 PM
Bbasso's Avatar
Default Re: Bad clutch makers (Kicker773)
ACT-
Ecedy-
Stock-
Old Jan 6, 2004 | 09:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danelot &raquo;</TD></TR><TR><TD CLASS="quote">Do a search for exedy. Quite few people posted problems with this clutch. I drove someone else's ITR with one in it. I liked the feel of it but would be weary of longevity. My oem works fine for now</TD></TR></TABLE>
in exedy's defense,i have installed a few of their factory replacement clutches and they always seem to do well.i can't comment on their performance products though.i was under the impression that Exedy manufactured clutches for some OEMs-am i wrong?if they do,their quality SHOULD be top-notch.
chris
Old Jan 6, 2004 | 10:28 PM
92TypeR's Avatar
FSAE
Default Re: Bad clutch makers (TeamNextGenChris)
Running strong on my exedy organic replacement clutch. 5 HPDE's and a few drag launches and it still holds and grabs. Although I will be switching to clutchmasters as soon as I get my 2.0L finished.
Old Jan 6, 2004 | 10:47 PM
itr-j's Avatar
Default Re: Bad clutch makers (92TypeR)
OE baby
all the way haha
Old Jan 7, 2004 | 06:24 AM
Jowee's Avatar
Default Re: Bad clutch makers (itr-j)
OEM is the best choice I made. I can't believe that I paid more for a clutch that couldn't even hold up as good as my stock.
For those who don't know, I got my car with 32k on the OEM clutch and drove it till about 50k with A LOT of stupid driving like 7k double clutches, lots of drag racing, and stupid rice boy stuff from back in the day. Yet it still lasted over a year from when I got it.
My ACT clutch was pure JUNK along with their customer service.
Now my new OEM clutch has lasted over 1 year with a few autoxs and lots of VTEC and NOT 1 SINGLE PROBLEM.
If you don't plan to add a ton of HP, OEM is the way to go. It may not be as stiff as an aftermarket clutch, but will last.
Old Jan 7, 2004 | 06:37 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">OEM is the best choice I made. I can't believe that I paid more for a clutch that couldn't even hold up as good as my stock.
If you don't plan to add a ton of HP, OEM is the way to go. It may not be as stiff as an aftermarket clutch, but will last. </TD></TR></TABLE>
my next clutch setup is going to be oem clutch disk/oem bearing with 1800lbs PP at 260whp.
Old Jan 7, 2004 | 07:02 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">Running strong on my exedy organic replacement clutch. 5 HPDE's and a few drag launches and it still holds and grabs. Although I will be switching to clutchmasters as soon as I get my 2.0L finished.</TD></TR></TABLE>
you're one of the few..
exedy organic in an ITR is a BAD BAD BAD idea.. ask me, smitdog, asahi, and others..
ACT HDSS here on #55.. I love it..
Old Jan 7, 2004 | 08:53 AM
98ITR#0020's Avatar
Original Stock clutch 60K and counting{starting to slip though}.. A few drag events and stupid driving too.
We put an Exedy in My brothers ITR hatch and it lasted over 35K. We put an Exedy in my friends GSR and it was done in under 10K I'm looking for a replacement as well....
Old Jan 7, 2004 | 09:22 AM
johnzm's Avatar
Default Re: Bad clutch makers (98ITR#0020)
i have only seen 2 broken clutches. both were ACT. screw dat!
im running an ACTION clutch, and i just pulled it out after many hard miles of use and it looks new,just like rocket said it would
Old Jan 7, 2004 | 09:35 AM
ACTman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">...My ACT clutch was pure junk along with their customer service.</TD></TR></TABLE>As I said on your original thread about this, I am sorry for the problems. You purchased an ACT stock replacement disc to go with your Xtreme pressure plate, instead of an ACT performance street disc that has steel backed linings. It is apparent that the outside of the linings blew off because of high rpm.
Still IMO we would have, or should have, worked with you to resolve the situation regardless of choosing the inexpensive disc. We are often complimented on our customer service and like most companies, sometimes criticised. I take the criticism seriously and we are always trying to improve. If I had time to do customer service myself, along with the job of maybe 20 other people I have working for me, it could be better. But then again, I have another other people working for me that do a better job than I ever could in their positions.
Old Jan 7, 2004 | 09:47 AM
quickchris's Avatar
Go with Clutch Masters.
Old Jan 7, 2004 | 10:39 AM
Asahi's Avatar
Default Re: Bad clutch makers (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
Exedy sucks ***. And "F" *** imports while we are at it!
Old Jan 7, 2004 | 10:42 AM
Chris93Si's Avatar
Unlike some others I haven't had any problems w/ my Exedy Organic
Old Jan 7, 2004 | 10:44 AM
Chris N's Avatar
Default Re: Bad clutch makers (Chris93Si)
Whichever clutch you get: watch out for 'installer error'.
A joke in reference to... well, most of you know/remember.
Old Jan 7, 2004 | 10:47 AM
GokuSSJ4's Avatar
I had friends with problems with ACT before were the tranny end up being destroy . ( dont have exactly the details ) but it was also a while back and im not sure to what extend ACT has improve on there clutches .
As far as Tilton goes , i would stay away from it . I blew 3 Tilton clutches , 2 of them in normal driving conditions .
An i believe it was the cause that i end up changing the tranny also .. messing first gear really bad , even after changing the synchros
