5g abs removal
Old Jan 6, 2004 | 04:44 PM
fw190bvi's Avatar
Default 5g abs removal
ive searched and theres nothing....my abs is shot, and i dont feel like fixing it...my ? is: if i just pull out the fuse box/pump/resovior/etc...but not neccesarily the lines to the wheels (im lazy), will there be any problems (another abs light/cel...etc..)??? also, is bleeding the system required??? i guess it runs nitrogen or something.....if not, ill just rip out the fuses
Old Jan 6, 2004 | 07:04 PM
iam7head's Avatar
Default Re: 5g abs removal (fw190bvi)
just take out the fuse if you dont looking forward for the extra weight reduction, well, not too much weight there anyway
Old Jan 7, 2004 | 11:20 AM
.bagged's Avatar
i just did this but was converting over completely to a 4th gen. you lines are pressurized with nitrogen..there is a nitrogen reservoir in the front of you engine cmt. near the battery. also your abs control unit you wont need either and that is in the trunk...you can run with no nitro reservior but if you remove the abs pump which is right near the abs relay(looks like a second fuse box) you will have to run new lines to the master...make sense?
///Apex
Jul 15, 2011 02:25 PM
packet
Honda Fit
12
Nov 23, 2008 07:53 PM
cslegacy
Sep 11, 2007 03:36 AM
vxnine
Jul 24, 2006 05:33 PM
rastropovitch
Oct 15, 2004 07:51 AM
