Pics of Cusco MC brace on ITR?
I just got mine in for Christmas and went to install it untill I realized you have to bend the brake line that goes into the MC to go in the other direction. I think BlackR had one on his b4 it got wrecked. Anyone install this b4 and have any tips?
Don't have to bend your brake line if you cut a slot in the MC brace.
I have one installed on my car and after measuring and making the slot it mounts right up. You'll have to mount it upside down though as it's made for RHD cars.
Edit: Imagestation seems to be down, if not I might have a pic of it installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 »</TD></TR><TR><TD CLASS="quote">I think BlackR had one on his b4 it got wrecked. Anyone install this b4 and have any tips? </TD></TR></TABLE>
I had one on my first itr and bent it when I totalled the car.
I have a 2nd one on my current itr.
They have worked great for me.
I did a write-up on it a long time ago... let me see if I can find the link.
Found it
https://honda-tech.com/zerothread?id=302787
Hrmm. My package says its for an EG4/6/8 part number 315 561. Would it still work?
https://honda-tech.com/zerothread?id=302787Hrmm. My package says its for an EG4/6/8 part number 315 561. Would it still work?
.....hrm, post up pics and we'll see!
Should be the same for eg and dc2... although eg may have a different geometry b/c of the different mc...
If you have measurements, I can compare to mine for you.
It seems to fit, except the place where the bolt it attached to the brace is closer to the firewall for the RHD, which makes it further away on the other side. I guess I just need to make the bolt extend further to work. Hopefully it should work or I'll see if Leo wants to send me the right one whenever he gets back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 »</TD></TR><TR><TD CLASS="quote">It seems to fit, except the place where the bolt it attached to the brace is closer to the firewall for the RHD, which makes it further away on the other side. I guess I just need to make the bolt extend further to work. Hopefully it should work or I'll see if Leo wants to send me the right one whenever he gets back.</TD></TR></TABLE>
Take the bolt out and remount it like shown EXACTLY as in this pic:
It should work fine then.
As for the Engine Dampener working with this... I don't know.
Engine dampener was too much $ and only dampened one side of the motor, so I never ordered it. Better to go with motor mount inserts: prothane upper and energy suspension lower, imho...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
Engine dampener was too much $ and only dampened one side of the motor, so I never ordered it. Better to go with motor mount inserts: prothane upper and energy suspension lower, imho... </TD></TR></TABLE>
Thanks bro, I'll try that.
I would personally go with a Hasport rear drag mount instead of the blingin engine dampner even though it's not JDM
I have the DRIVE MC Brace--> MADE FOR LHD CARS
these things are SOLID billet aluminum . . .
anyway just though this would solve all your problems about making the Cusco one work. check em out at http://www.driverr.com
Modified by scLSteg at 7:40 AM 1/8/2004
dnt94civic
Aug 30, 2002 06:03 AM
