So how many of us have messed up blower controls?
Old Jan 6, 2004 | 03:30 PM
FourthGenHatch's Avatar
Default So how many of us have messed up blower controls?
I've heard many people say their #1 postion, or #2 postion on the blower speed doesn't do anything, or the speed never changes no matter what you do. It might just be me but I noticed today my #2 doesn't do much anymore where before it did. I think my heating system is in need of an overhaul. Helms has a big list of things to test for. I think I might do that tomorrow and maybe scan in those pages if any of you would like to fix yours also.
Old Jan 6, 2004 | 03:41 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: So how many of us have messed up blower controls? (FourthGenHatch)
If the fan does work on certain speeds, check the blower resistor
located behind the glovebox;
take out the two screws and check the coils,
Old Jan 6, 2004 | 03:48 PM
All you have to do with the resistor is test for continuity between prongs 2 and 4.
My mulimeter is at work though, maybe I will pick it up after school tomorrow.
Old Jan 6, 2004 | 04:11 PM
Home Skillet's Avatar
I'm having problems with the vent controls more so than the blower controls. My blower controls are sticky when it's cold but when it warms up they seem fine. I guess the previous owner liked to over use Armor All
Old Jan 6, 2004 | 05:11 PM
tsjeff's Avatar
Default Re: So how many of us have messed up blower controls? (Home Skillet)
my blower doesn't work on number 1 but I never use it, I just use 2 instead.
Old Jan 6, 2004 | 05:15 PM
I Gotta Question's Avatar
Default Re: So how many of us have messed up blower controls? (d1crx)
yeah my blower **** all together is broke on both of my rex's I dont know wha tyou guys mean by the blower itself.
Old Jan 6, 2004 | 07:25 PM
JrCRXHF's Avatar
Default Re: So how many of us have messed up blower controls? (91_CRX_Si)
mine does not work on 1 or 2 and i have a broken heat so i have to reach under and turn on the heat which is like once a year. Because i drive the car in the summer
Old Jan 7, 2004 | 11:59 AM
I checked all my heater stuff today and adjusted all the cables.
I ohmed out my resistor on 2 & 4 and it showed no continuity. So my problem is probably that. I tested the switch also and it was good. So I'll go get a resistor at the junkyard or maybe order a new one if they are cheap enough.
Old Jan 7, 2004 | 12:34 PM
Jet Black's Avatar
dont even botehr getting one from a civic if its too much troubel to find one.
I just grabbed one from an accord and soldered the coils back on.....if you dont have a strong soldering iron you`ll have to use a butane torch tho, as the metal is quite thick guage.
Old Jan 7, 2004 | 12:42 PM
Default Re: So how many of us have messed up blower controls? (Jet Black)
Actually they are only $21 from hondaautomotiveparts.com
Thats better than a junkyard one since it is brand new you know it is going to work for another 15 years.
Old Jan 7, 2004 | 12:49 PM
91' LS-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_CRX_Si &raquo;</TD></TR><TR><TD CLASS="quote">yeah my blower **** all together is broke on both of my rex's I dont know wha tyou guys mean by the blower itself.</TD></TR></TABLE>
Yep, all i gave is the wire hanging out.Pull wire:ON. Push in wire:OFF.
Old Jan 7, 2004 | 01:03 PM
90JPRCRX's Avatar
Smells like Tuna
Default Re: So how many of us have messed up blower controls? (91' LS-VTEC)
mine doesnt work on #1 but it feels like the switch is broke or something, it just slides easily to #2, is anybody elses like that?
all my push buttons work good, the **** for the slider is off *i have it* and the turn **** is cracked and pushed in *common problems
the defroster is a panzy when its freezing outside the car fogs up and the defroster slowly but surely blowes out the door vents, the rear side windows are always fogged, my rear defroster works the best
Old Jan 7, 2004 | 02:48 PM
JrCRXHF's Avatar
Default Re: So how many of us have messed up blower controls? (88JPRCRX)
mine is so broken. i don't know what the problem with mine is because i put a new motor in when i got it because the motor was bad and it has always not worked on one or 2 so maybe it can be the switch sometimes too.
ferio_11
Dec 2, 2017 05:05 AM
_EF9
Jul 29, 2013 05:37 PM
94Jlude
Jan 3, 2009 03:41 PM
idewson
Mar 4, 2007 07:34 AM
kuckimonster2
Sep 7, 2004 08:00 PM
