poeple using washer trick for rear camber... read!
Old Jan 6, 2004 | 03:09 PM
xXx Justin xXx's Avatar
Default poeple using washer trick for rear camber... read!
i know how to do it... just wondering if it changes for a car with rear disk brakes. going to do my gf's 4 door ex (95). wondering what thickness washers and how many per bolt to use. she has a 2" drop..and should i get a longer bolt as well...
front is corrected with ingalls....
Old Jan 6, 2004 | 03:20 PM
00EM1Si's Avatar
Default Re: poeple using washer trick for rear camber... read! (SOHC Beast)
3/4" Washers and 3 washers would be fine but if u want a little camber put 4
Old Jan 6, 2004 | 03:24 PM
SIRIUS's Avatar
Default Re: poeple using washer trick for rear camber... read! (Krazipeenoi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krazipeenoi &raquo;</TD></TR><TR><TD CLASS="quote">3/4" Washers and 3 washers would be fine but if u want a little camber put 4</TD></TR></TABLE>If you wanted camber wouldn't you put less washers in?
Old Jan 6, 2004 | 03:31 PM
chad's Avatar
Moderator
Default Re: poeple using washer trick for rear camber... read! (SIRIUS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS &raquo;</TD></TR><TR><TD CLASS="quote">If you wanted camber wouldn't you put less washers in?</TD></TR></TABLE>
exactly....i only have 1 behind each bolt
and i'm lowered 2 inches too
Old Jan 6, 2004 | 03:33 PM
00EM1Si's Avatar
I'm saying that its good to have some camber, so you can still have some handling and I'm just saying if he wanted to have little camber so his tires won't wear as bad, then he could add and extra washer. And yes there will be more camber when you take off washers...
Old Jan 6, 2004 | 03:35 PM
Default Re: poeple using washer trick for rear camber... read! (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
and i'm lowered 2 inches too</TD></TR></TABLE>
how much - camber do you still have. i dont want any positive on it... i had two behind each bolt on my old eh2 and it was lowered on coilovers... 1/8" gap on 16's... and it almost looked like it had positive camber...
alittle negative camber is better that positive imo... just dont want her tires wearing out on the inside. tring to do this tomorrow, so keep the responces coming.
Old Jan 6, 2004 | 04:22 PM
TeamNextGenChris's Avatar
i have two washers on both my cars,both lowered about 2.5"....main thing to do if you're concerned about wearing out the insides of the tires is to get an alignment after you lower it to get the toe set correctly.if you lower the car,and don't correct the toe,you will wear the tires out regardless of your camber adjustment.
chris
Old Jan 7, 2004 | 06:57 PM
Skip01's Avatar
Default Re: poeple using washer trick for rear camber... read! (TeamNextGenChris)
I've heard of the washer trick but not specfics,what exactly do you put washers on and what type of washers?I searched already.thanks.
Old Jan 7, 2004 | 07:04 PM
Default Re: poeple using washer trick for rear camber... read! (Skip01)
yuo just put washer sunderneath part #17,between it and the chassis.
this ismply spaces the upper arm and top of the trailing arm out.
chris
Infinity_Racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip01 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard of the washer trick but not specfics,what exactly do you put washers on and what type of washers?I searched already.thanks.</TD></TR></TABLE>
you put the washers between the body and where the upper lca bolts up to...i have 2 regular washers on my car
Old Jan 7, 2004 | 07:06 PM
itsJDMyo's Avatar
Default Re: poeple using washer trick for rear camber... read! (Infinity_Racer)
do you have to get an alignment after you do the washer trick??
Old Jan 7, 2004 | 07:12 PM
aphex23's Avatar
Default Re: poeple using washer trick for rear camber... read! (b00st)
so is it common practice to do the camber correction when lowering? or is it one of those things you guys do, just to do? i have heard both ways, if you arent lowering more than like 2.5, dont worry about it, others say, any lowering, and you need too... i am planning on lowering about 1.8 around i think... would i need a camber kit and do the washer deal? sorry to jack the thread, just saves a new one from being started
Old Jan 7, 2004 | 08:06 PM
Skip01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">yuo just put washer sunderneath part #17,between it and the chassis.
chris</TD></TR></TABLE>
Sorry.I'm still confused so do I put a washer on bolt #28.
Old Jan 7, 2004 | 08:17 PM
no the washers go under the part to the left of the #17.bolt #25(there are actually two of them)goes through pat #17 and the washers,into the car chassis.
some quick help from Photoshop :
chris
Old Jan 7, 2004 | 08:18 PM
743power's Avatar
you put the washers behind part number 17, which bolt # 25 goes through.
BatuKing's Avatar
Sorry.I'm still confused so do I put a washer on bolt #28.</TD></TR></TABLE>
No you put it behind the bolts that attach to the body of the car
it is good practice to do an alignment on it and also if you know the person doing the alignment they do have special washers designed to go behind there for specific thickness needed.
Old Jan 7, 2004 | 08:56 PM
Mike Ockhurts's Avatar
Default Re: poeple using washer trick for rear camber... read! (BatuKing)
http://home.earthlink.net/~civ....html
here ya go
Old Jan 7, 2004 | 09:27 PM
itsJDMyo's Avatar
Default Re: poeple using washer trick for rear camber... read! (lilredridinghood)
so you wouldn't need to get an alignment at shop if you do the washer trick? because i heard you have to if you get a camber kit
Old Jan 7, 2004 | 10:11 PM
civic_tuned's Avatar
on mine i needed the bolts 2 on each side. The size is 10x1.25x40 i believe some of this guys used them too. 10.9 grade is recommend 8.8 will do. U can get them at Pep boys for 1.00 each. Hope this helps and good luck bro.
Old Jan 8, 2004 | 04:45 AM
Skip01's Avatar
Thanks for the help everyone,really good info.peace.
Old Jan 8, 2004 | 04:53 AM
willyboyK20's Avatar
Default Re: (Skip01)
i put two washers per bolt on each side but i think it needs more or get a better alignment because the the inside of my rear tires are starting to look funny
Not because thier worn or anything, the tread is still there but it looks different then the rest of the tire.
Old Jan 8, 2004 | 05:03 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st &raquo;</TD></TR><TR><TD CLASS="quote">so you wouldn't need to get an alignment at shop if you do the washer trick? because i heard you have to if you get a camber kit</TD></TR></TABLE>
You should always have an alignment done any time you mess with the suspension.
Old Jan 8, 2004 | 05:16 AM
Viva la Nubz's Avatar
anyone heard anyone having problems with bolts tearing out? im gonna be using longer bolts as soon as i feel like doing it, they've been in garage for 8 months.just wondering thanks.
Old Jan 8, 2004 | 06:21 AM
Default Re: (willyboyD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyD16 &raquo;</TD></TR><TR><TD CLASS="quote">i put two washers per bolt on each side but i think it needs more or get a better alignment because the the inside of my rear tires are starting to look funny
Not because thier worn or anything, the tread is still there but it looks different then the rest of the tire.</TD></TR></TABLE>you need an alignment-the weird wear you're seeing on the inside is most liekly due to out of adjustment toe.
chris
Old Jan 8, 2004 | 06:25 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: poeple using washer trick for rear camber... read! (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
You should always have an alignment done any time you mess with the suspension.</TD></TR></TABLE>
ditto. why try to guess with washers? get an alignment, and know exactly where your setting are.
