Super Charge or Turbo a 99 prelude SH?
Old Jan 6, 2004 | 02:57 PM
ThefirstPACT's Avatar
Default Super Charge or Turbo a 99 prelude SH?
A freind in the shop is trying to convince the parts guy to super charge his prelude! I say that he turbos it! What would be better in your guys opinion? Is one any harder on the engine than the other?
Old Jan 6, 2004 | 03:07 PM
Kidd_Stylez's Avatar
Default Re: Super Charge or Turbo a 99 prelude SH? (1CAMcan)
you might get a better responce if you were to post this topic in the prelude forum rather than F/I. Supercharge, thats my opinion but it all depends on what one wants out of their driving experience.
Old Jan 6, 2004 | 03:21 PM
leadfoot78's Avatar
Search the FI forum, u will find how much better turbo is. Supercharging is easier but it will not make as much power as a good turbo set up, not even close.
Old Jan 6, 2004 | 11:02 PM
tHeSoCk's Avatar
I went supercharger but thats just me. Most people in this fourm like turbos
Old Jan 7, 2004 | 12:27 AM
EG6chick's Avatar
If its a daily driver, a SC is a better route to take , but if youre planning on taking it to the track and drag racing it a lot, turbo is the way to go. Depends if you like having more low end power for short street races and such, or if you want more top end power.
I should have gotten a turbo instead, but the SC is undetectable unless you can hear it. No FMIC to be seen. SC draws less attention to your car too.
Old Jan 7, 2004 | 12:28 AM
EG6chick's Avatar
Default Re: Super Charge or Turbo a 99 prelude SH? (EG6chick)
Arent SC's less harsh on the engine since theyre usually in vacuum unless you step on it to make boost?
Old Jan 7, 2004 | 12:38 AM
boostin lude's Avatar
go turbo man. .. when you have the sc you're ALWAYS boostin. . . unlike with a turbo if you stay in vaccum.
Old Jan 7, 2004 | 01:03 AM
EG6chick's Avatar
Default Re: (boostin lude)
Sorry but your not always in boost with a SC according to my boost gauge.. its usually stays in vacuum in just regular driving.
Modified by EG6chick at 10:16 AM 1/7/2004
Old Jan 7, 2004 | 08:46 AM
tHeSoCk's Avatar
yea, with a sc you can stay out of boost just as easy as a turbo. Sometimes it's *easier* depending upon how early your turbo spools at & the sc is a much less expensive mod if you don't want over 260WHP ish.
Old Jan 7, 2004 | 08:56 AM
green_GSR's Avatar
Supercharger:
Pros: Good power down low, bolt-on, less expensive, CARB legal
Cons: Unintercooled boost = higher intake temperature = less power = more prone to knock, less upgrade potential
Turbo:
Pros: Intercooled boost (with intercooler), more power, a lot of upgrade potential, BOV
Cons: More than just "bolt-on", more lag than supercharger, usually more expensive
That's the very general idea.
Old Jan 7, 2004 | 09:02 AM
Revi's Avatar
Default Re: Super Charge or Turbo a 99 prelude SH? (green_GSR)
Lets not forget your driving an SH, and more than likely a turbo will fry the unit. Jackson Racing has a supercharger made to run with the ATTS unit, but it will still not be able to handle the extra torque. A turbo will for sure fry the unit, specially if your gonna be boosting high.
Or you can do what im doing and ditching the SH Block and tranny and going with the base units. But then again im building a 20+psi turbo set-up.
Old Jan 7, 2004 | 09:09 AM
Default Re: Super Charge or Turbo a 99 prelude SH? (Revi-Ra)
thanks everyone for the comments and suggestions!
Old Jan 7, 2004 | 09:17 AM
gdrum's Avatar
id SC it unless u are a pro and know what ur doing.............SC is just safer when it comes to the h22...
Old Jan 7, 2004 | 10:30 AM
mrmonk's Avatar
EVERYONE will tell you to go turbo.... I think that should signify a valid point.....
GO TURBO....
there are so many reasons why one should install a turbo, I mean Hondas were practically built for turbos.
Old Jan 7, 2004 | 10:34 AM
mrmonk's Avatar
Default Re: Super Charge or Turbo a 99 prelude SH? (mrmonk)
Oh BTW, dont listen to that reliability B.S. issue with turbos.
I mean i got a stock gsr and F-ed it up already just from a Mis Shift.
If properly tuned and DRIVEN; a turbocharged honda can be just a reliable as a stock one and run just as or even more efficiently.
Old Jan 7, 2004 | 10:36 AM
leadfoot78's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra &raquo;</TD></TR><TR><TD CLASS="quote">Lets not forget your driving an SH, and more than likely a turbo will fry the unit. Jackson Racing has a supercharger made to run with the ATTS unit, but it will still not be able to handle the extra torque. A turbo will for sure fry the unit, specially if your gonna be boosting high.
Or you can do what im doing and ditching the SH Block and tranny and going with the base units. But then again im building a 20+psi turbo set-up.</TD></TR></TABLE>
^^^ He is right the H22 is one of the worst motors to boost, I forgot it has the FRM cylinders and probably the weakest ringlands of all honda motors. I just wouldn't boost the H22 at all.
Old Jan 7, 2004 | 10:48 AM
mrmonk's Avatar
Default Re: Super Charge or Turbo a 99 prelude SH? (leadfoot78)
how much boost u talkin about? if your talkin about 20 psi then yes you are correct
Old Jan 7, 2004 | 10:49 AM
Bulldogg83's Avatar
supercharge......
Merlin1068
Sep 23, 2002 08:51 AM
Sigma D
Nov 29, 2001 05:37 PM
Butthead
Nov 7, 2001 06:29 PM
