still not reving
Old Jan 6, 2004 | 02:44 PM
bigblu333's Avatar
Default some help with premature rev limiter would be appreciated
thanks everyone for the help lastnight i rechecked all my wiring at the ecu, tried three seperate ecu's checked all wiring at the dizzy and all an still cant get the thing to rev past 3500, for the ones who didnt see previous post, converted 90 dx to mpfi and running 91 ecu and not able to get the engine to rev past 3500 also curious if timing being off would be enough to cause this?? maybe a tooth one way or the other on timing belt
Modified by bigblu333 at 12:22 AM 1/7/2004
Old Jan 6, 2004 | 05:03 PM
redeyeef2's Avatar
Default Re: some help with premature rev limiter would be appreciated (bigblu333)
Timing would not make that large of an effect. No CEL???? I would check the color of the wires plugged into your IAC valve. Sounds like they might be wrong, or not connected.
http://www.redeyefabrication.com
Old Jan 6, 2004 | 05:07 PM
Timmah!!'s Avatar
Default Re: some help with premature rev limiter would be appreciated (redeyeef2)
Does it just stop abruptly at 3500 or does it slowly get to that RPM and then just cant go any further?
Old Jan 6, 2004 | 05:30 PM
rags2riches's Avatar
Default Re: some help with premature rev limiter would be appreciated (azroth)
make sure you swapped the 2 wires on the tps sensor, also make sure you got c1 & c2 not reversed.
Old Jan 6, 2004 | 05:36 PM
bigblu333's Avatar
get there quick and stops sharply
Old Jan 6, 2004 | 07:20 PM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblu333 &raquo;</TD></TR><TR><TD CLASS="quote">get there quick and stops sharply</TD></TR></TABLE>
Not your timing belt then, timing makes it struggle like a bitch. At least when its severely retarded....
strugler
May 2, 2010 05:24 PM
90jdmcrxdude
May 14, 2006 04:36 PM
hondaman86
Mar 21, 2006 02:58 PM
T--Rex
Jul 5, 2004 11:04 AM
