HKS S35i Problem.
Old Jan 6, 2004 | 01:23 PM
vteec's Avatar
Default HKS S35i Problem.
Hi,
I just bought a set of HKS S35i Iridium plugs for my R.
When i went to install them i dropped one of them !!
Now the tip of the plug is touching the 'metal arc'...i straightened it a bit up but i noticed that a little tiny part if the tip is gone !!
Do you think it is safe to use this plug pls?
Will it hurt my engine in any way?
Pls help me guys.
rgds,
Old Jan 6, 2004 | 01:51 PM
Denny's Avatar
Default Re: HKS S35i Problem. (vteec)
replace it, dont risk it
Old Jan 6, 2004 | 02:10 PM
JjuuN R's Avatar
ouch. that plug won't function like the other 3, butterfingers
Old Jan 6, 2004 | 09:55 PM
vteec's Avatar
Default Re: (JUN.R)
Is it ok too buy just one plug or is it better to replace them all to have a new set?
The other plugs have no damage.
rgds,
Old Jan 6, 2004 | 10:24 PM
epy's Avatar
epy
Default Re: (vteec)
just buy one HKS S35i Iridium plug.
Old Jan 6, 2004 | 10:26 PM
DsITR's Avatar
It needs to be gapped correctly, and then it would work fine.
BUT, think of the damaged piece breaking off and floating about in your combustion chamber.
If you can't find an HKS for a while, just pick up some NGK's
EDIT: just saw your 2nd post, buying one plug is fine..
Old Jan 7, 2004 | 03:30 AM
vteec's Avatar
Default Re: HKS S35i Problem. (DsR)
ok thanks a lot my friends
TQuach
Nov 24, 2005 10:28 PM
d16efsedan
Feb 4, 2005 07:51 AM
UltimX
Jun 7, 2004 04:04 PM
Scharged2000GsR
Oct 14, 2003 05:05 PM
RineRacing
Jul 27, 2001 04:34 AM
