Best D series tranny for top speed ?
Old Jan 6, 2004 | 01:06 PM
subgeniusdude's Avatar
Default Best D series tranny for top speed ?
Was wondering what the best tranny for top end would be...my std hatch w/mpfi swap and intake topped out at 118 mph yesterday with the crappy 4 speed..not too bad considering it came stock w/70 hp but not terrific either...
Old Jan 6, 2004 | 01:09 PM
Malgerus's Avatar
Default Re: Best D series tranny for top speed ? (subgeniusdude)
Hf tranny... haha
Old Jan 6, 2004 | 01:25 PM
USDM 4G VTEC's Avatar
i cant say now since i am at work and dont have my favorites
but go to google and do a search for CRX Math
u will find a page that has all the tranny speed calculator
Old Jan 6, 2004 | 01:30 PM
Timmah!!'s Avatar
Default Re: Best D series tranny for top speed ? (USDM 4G VTEC)
I think The Si tranny will run out of gearing at about 130 with a 7200ish RPM redline.
But who wants to run their motor at 7200 RPMs for a long period of time.
Old Jan 6, 2004 | 01:34 PM
Default Re: Best D series tranny for top speed ? (azroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth &raquo;</TD></TR><TR><TD CLASS="quote">I think The Si tranny will run out of gearing at about 130 with a 7200ish RPM redline.
But who wants to run their motor at 7200 RPMs for a long period of time.</TD></TR></TABLE>
nope
mechanicaly the Si tranny @ 7500 can do 157 mph by that page
http://crx.honda-perf.org/math/
Old Jan 6, 2004 | 02:13 PM
yellowcrx1991's Avatar
You'd better have some major power to back it up, but the HF tranny would net you the highest top speed.
With roughly 120hp, my d16a6 with an HF tranny struggled to reach 95mph. I think 110mph was the fastest I could reach; and that was full throttle for about 30 seconds.
All that aside, I would say the best thing about the HF tranny is 1st gear, which allows you to run up to 50mph before hitting red.
Old Jan 6, 2004 | 02:27 PM
another_crx's Avatar
Default Re: Best D series tranny for top speed ? (yellowcrx1991)
Car bounced off the limiter at 145 with complete stock si rex. I was trying to blow the engine but the ****** just wouldnt go
Old Jan 6, 2004 | 03:12 PM
Timmah!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
nope
http://crx.honda-perf.org/math/</TD></TR></TABLE>
I was guestimating off the top of my head.
Old Jan 6, 2004 | 05:33 PM
green91's Avatar
ok kinda curious but im about to throw a d1y8 in my hatch and im wondering what kind of 1/4 mile difference i would have between my DX tranny and a Si tranny
Old Jan 6, 2004 | 05:38 PM
91hob20hb's Avatar
I have 91 hf and easily reached 110 with plenty of tach to go so i would use hf for top speed but i also like si tranny too go low gear and still can reach 120 easily which is not really need unless you racing on the freakin highway or got enough hp to get you up to that speed on 1/4 mile track
Old Jan 6, 2004 | 06:05 PM
GroundZer0 336's Avatar
Default Re: (91hob20hb)
i would think the si transmission would go pretty high, on the highway the other day i hit around 125 in 4th gear, with everything stock cept for i/e. so having around 35-30 mph per gear, i should mathimatically be able to hit around 150 in fifth gear right. not sayin my engine could take it but i COULD right? cuz i dont want to try that fast
Old Jan 6, 2004 | 06:10 PM
Civic138's Avatar
i always hit 110 on the hwy with no problem, in my dx with a std tranny,with only a cheap *** ebay muffler.
Old Jan 6, 2004 | 06:57 PM
FourthGenHatch's Avatar
Default Re:
I'd bet the DX tranny can go the highest. You have 5 gears and they are high as hell. I'd bet my ZC tranny would top out way before my old DX one did.
Old Jan 6, 2004 | 07:01 PM
Default Re: (green91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">ok kinda curious but im about to throw a d1y8 in my hatch and im wondering what kind of 1/4 mile difference i would have between my DX tranny and a Si tranny</TD></TR></TABLE>
i ran a 15.4 with DX tranny
and ocne i hybrid it into a DX/Si tranny i ran a 15.1
so i can say with timeslips to back it up that the Si tranny is 0.3 seconds faster than the Si
Old Jan 6, 2004 | 07:02 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Re: (subgeniusdude)
4speed Std tranny i heard had the best top speed,
now u need to go to somewhere like the salt flats to get it all the way up there
oh and enjoy your aviatar while u can , or switch it. mods will lock it up.
Old Jan 6, 2004 | 07:19 PM
blah13's Avatar
Default Re: Re: (ind3ciso)
Everybody here also needs to consider what size your tires are. Larger diameter tires = longer "gears" per se. Tranny gearing isn't set on how fast it will let your car go, the tires are the last ratio.
Old Jan 6, 2004 | 07:20 PM
JonGP4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">4speed Std tranny i heard had the best top speed,
no way the 4 speed would go that high.. that 4th gear sucks *** on the freeway
Old Jan 6, 2004 | 08:15 PM
90civichbsi's Avatar
i got my old d16a6 to 127 at 6500 rpms once
Old Jan 7, 2004 | 01:21 AM
FURACERMAN's Avatar
130 in my stock freak lx. Ran out of road, I could have gone a little more.
Old Jan 7, 2004 | 03:48 AM
spiceisler's Avatar
Default Re: Best D series tranny for top speed ? (FURACERMAN)
I would say the Dx/Hf 5-speed. I had a 4-speed in my Si with a Zc and I used to hit 110mph @ 7200 in third gear, 135 in 4th @ 6500. At that point I had no more power. My goal is 150 with the Dx 5-speed after turboing the Zc.
Old Jan 7, 2004 | 08:44 AM
I8ayellowcrayon's Avatar
What is the HF gearing? Since it is so highly geared though, you will need some more power. I've heard a stock DOHC ZC/ZC tranny CRX will do 130. The ZC has the same final drive as the DX tranny, but has a closer ratio through the gears.
Old Jan 7, 2004 | 08:47 AM
I Gotta Question's Avatar
An hf tranny should get you to around 240 in 5th gear I use to down shift to second on the highway it really quite fun.
Old Jan 7, 2004 | 09:24 AM
Jet Black's Avatar
Default Re: Best D series tranny for top speed ? (91_CRX_Si)
240? You'd need an insane ammount of hp for that
what about the VX tranny....allthough its hydro
Old Jan 7, 2004 | 12:43 PM
Default Re: Best D series tranny for top speed ? (Jet Black)
yeah I know you would but that tranny doesnt top out until around thereplus the tranny would prolly be shot by that speed.
92gsrsupercharged
Sep 30, 2007 03:54 PM
GT30RSX
Feb 21, 2007 10:45 PM
whole9
27
Dec 24, 2006 12:01 AM
92KillerBee
Sep 21, 2003 08:27 AM
