In need of Camshaft and head guidance!
Old Jan 6, 2004 | 12:46 PM
Shadow Templar's Avatar
Default In need of Camshaft and head guidance!
Hi, I'm going to undergo surgery on my 92 civic DX. I am taking a cam out of a D16A6 and placing it in my D15B7. My engine has 175,000 miles on it and i believe it may be time to do some valvebody and springs and what not to it, and Im looking for advisory on what exactly I should do/use (brand names) for this operation. My intentions are to have a fast daily driver with good fuel economy and the ability to put stoplight challengers in their place. I used to specialize in working on V8 engines, but I have put myself into the future and I have noticed that even knowing what I do, I am very behind, so I seek everyones guidance. Thank you.
Old Jan 6, 2004 | 02:06 PM
hatched92's Avatar
imo the d15b7 wont really be "fast" unless you put a turbo kit on it and then it would be ok but if you build it for boost you can push about 200-250whp with good tuning. i'm guessing it's a hatch? you can do a d16z6 swap super cheap and add and extra 30hp out of the box.
Old Jan 6, 2004 | 02:41 PM
Default Re: (hatched92)
its a sedan, im sorry i forgot to add that part. no, im sticking with original motor, and i don t want a turbo, ive had bad experiences with them (don t ask) if i was going to do some FI i would use a supercharger, but im stayin all motor. its just supposed to be a quick as possible daily driver, without compromised fuel economy(i drive pretty far) i know the parameters are shitty, but its what i have to work with
Old Jan 7, 2004 | 06:23 PM
Default Re: (Shadow Templar)
bump
Old Jan 7, 2004 | 08:22 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadow Templar &raquo;</TD></TR><TR><TD CLASS="quote">its a sedan, im sorry i forgot to add that part. no, im sticking with original motor, and i don t want a turbo, ive had bad experiences with them (don t ask) if i was going to do some FI i would use a supercharger, but im stayin all motor. its just supposed to be a quick as possible daily driver, without compromised fuel economy(i drive pretty far) i know the parameters are shitty, but its what i have to work with</TD></TR></TABLE>
Typical response of a muscle-head
What in the world makes you think that a supercharger on a newer import is anymore reliable than a turbo? These aren't the old musclecars....
Old Jan 7, 2004 | 08:48 PM
kommon_sense's Avatar
Default Re: (LudeyKrus)
Given any thought to getting the cam reworked? http://www.exospeed.com offers regrinds on the a6 cam. They have 4 or 5 different stages of grinds. You should also consider a z6 or y8 tranny. That will make a world of difference. Or go with the vti-r tranny which came with an oem lsd. You can find it at http://www.hyperducktuning.com .
Old Jan 8, 2004 | 06:50 PM
Default Re: (kommon_sense)
Turbos suck, im sticking by it. ya, i worked on V8s for 3 years, its not a bad thing to be a muscle-head. Shoving exhaust fumes back into my motor doesn t even remotely sound healthy. Ive seen a brand new mitsubishi blow out its turbo and pour oil all over the ground, and its a new import. stupid mitsy s ya i had every intention of changing my tranny to an Z6 cuz the gears are longer in my stock tranny, i was wondering if it would bolt in or is there an adapter i need. i have a standard in case that was in question.
Modified by Shadow Templar at 4:19 AM 1/9/2004
Old Jan 8, 2004 | 07:12 PM
gloryhog's Avatar
first off your not shoving exaust fumes into the combustion chambers , I dont think you know jack about a turbocharger. the exuast spins a turbine in its own housing which has a shaft ran into another housing w/ the compressor turbine which comp. the air drawn into it via the air filter, then blows that compressed clean air into the charge pipe which travels through the intercooler then to the intake manifold. now then how is that feeding exaust fumes into the combustion chambers??? GLORYHOG
Old Jan 8, 2004 | 07:41 PM
Default Re: (gloryhog)
well i never said it went into the combustion chambers, but anyways. it just seems like a risk that doesn t need to be taken, like i said ive seen enuff failures to not want one. i do appreciate having it explained to me, even tho not in the nicest terms. im only upgrading the OEM. well, aside from the cam switch, ive heard the D16Z6s intake manifold is the best at breathing and all D series I.M. are interchangeable. ill start small now. exhaust should probably come after.
Old Jan 13, 2004 | 08:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadow Templar &raquo;</TD></TR><TR><TD CLASS="quote">Turbos suck, im sticking by it. ya, i worked on V8s for 3 years, its not a bad thing to be a muscle-head. Shoving exhaust fumes back into my motor doesn t even remotely sound healthy.
Modified by Shadow Templar at 4:19 AM 1/9/2004</TD></TR></TABLE>
you really don't know how a turbo works do you?
You can find a very good high level explanation here :
http://auto.howstuffworks.com/turbo.htm
Old Jan 14, 2004 | 08:30 AM
Thank you, no, i didn t know, but i do now. knowin how they worked still doesn t change some experiences. maybe later ill change my mind, but for now, im stayin all motor.
nahnah05
Jul 23, 2010 05:08 PM
TxFireman1972
22
May 13, 2010 09:46 AM
BrakeDanceJ
Jan 22, 2010 09:08 AM
Dent Free
12
Sep 27, 2004 06:19 AM
92CivicDX
10
Aug 15, 2002 03:52 AM
