Sway bar, tie bar combo
Old Jan 6, 2004 | 12:36 PM
Steve_O's Avatar
Default Sway bar, tie bar combo
I have the Skunk rear lower tie bar and i'd like to add a rear sway bar (Skunk2 most likely or ST) as well but so far i'm noticing that sway bar pics i've seen look like they interfere with a lower tie bar (even before a beaks kit is used)
just wodering if anyoe has a tiie bar and sway bar from separate companies. i know the comptech combo i've rerad is best but i'd have to buy GSR or Del Sol VTEC rear LCAs to make it work on my EG.
i was reading a past post about subframes being torn out and i was going to get the hbeaks kit but it sits almost right next to the LCA bolt where my Skunkw bar mounts up to (see pics below)
beaks mounting point:
ST sway bar mounting point:
Skunk2 tie bar mounting point:
to me it looks like i either get the Comptech cet-up if i want a tie and sway bar otherwiose i have to settle for one or the other. **EDIT** the Spoon rear lower tie looks like it's designed to clear the sway bar mounting points on the EG chassis but I can't find a pic of one actually on an EG, they just show ones for the EK
LOL help
P.S. i've also been readin that thebeaks kit still rips out. any truth to this on the EG HBs?
Modified by 519RACING at 10:02 PM 1/6/2004
Modified by 519RACING at 10:11 PM 1/6/2004
Old Jan 6, 2004 | 12:43 PM
viprcr1's Avatar
Default Re: Sway bar, tie bar combo (519RACING)
i think you should get the SRR sway and tiebar kit. It is quality and its great all around..
Old Jan 6, 2004 | 01:42 PM
oneslowcivic's Avatar
i would go progress...thats what my EJ and my friends Si ride on..here's a shot of mine:
lovin it, but i guess a tie-bar would not work w/ it... one advantage, tho is that they use brackets that drop the sway bar lower than factory mounts...helps w/ clearing the exhaust piping on my hatch!
Old Jan 6, 2004 | 02:00 PM
cre18's Avatar
i'm running the beaks rear 22mm itr sway bar and reinforcement kit and a benen rear tie bar no interference
Old Jan 6, 2004 | 02:06 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: Sway bar, tie bar combo (cre18)
I don't know why people even bother with those tie bars anyway. Just more bling for people's headlights to shine off I guess.
Do it right and go Comptech.
Old Jan 6, 2004 | 02:49 PM
filthyCREX's Avatar
Default Re: Sway bar, tie bar combo (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">I don't know why people even bother with those tie bars anyway. Just more bling for people's headlights to shine off I guess.
Do it right and go Comptech.</TD></TR></TABLE>
it was my understanding that they actually work! maybe not tho?
paint it flat black, thats what i'm going to do!!
Old Jan 6, 2004 | 03:09 PM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">Do it right and go Comptech.</TD></TR></TABLE>
exactly what i was gonna say. i bet you can find a set of lcas for pretty cheap.
Old Jan 6, 2004 | 03:25 PM
EJ1_519
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cre18 &raquo;</TD></TR><TR><TD CLASS="quote">i'm running the beaks rear 22mm itr sway bar and reinforcement kit and a benen rear tie bar no interference
That looks like a nice setup
Old Jan 10, 2004 | 07:58 PM
MrIllegalX's Avatar
what is necessary to put a rear sway bar on a 97 HX? I figured it was just a sway (perferably aftermarket) and a beaks kit, but now I'm not sure.
honda_coupe
May 24, 2009 05:04 PM
94b16coupe
Suspension & Brakes
Jan 4, 2008 05:22 AM
biggs2.3
Nov 22, 2004 06:55 PM
Sassafrass
26
Feb 9, 2004 05:16 PM
94DelSolVTEC
Mar 6, 2002 08:34 AM
