Acura Legend Injectors
Old Jan 6, 2004 | 11:29 AM
abeaujuin's Avatar
Default Acura Legend Injectors
Will injectors from a 93 Legend work on an 94 accord?
Old Jan 6, 2004 | 12:40 PM
The_Todd's Avatar
Farts in the shower
Default Re: Acura Legend Injectors (abeaujuin)
The legend was a v6....going into 4 banger,I wouldn't think so but I have been wrong, I would look into prelude injectors or aftermarket ones
Old Jan 6, 2004 | 12:46 PM
abeaujuin's Avatar
Default Re: Acura Legend Injectors (VRDrvr)
The top looks alike and also does the connectors, but the bottem part doesn't look the same it doesn't even use an oring.
Old Jan 6, 2004 | 12:55 PM
twkdCD595's Avatar
what is the purpose, you need more fuel for a n/a buildup or you thinking something f/i?
there are lots of choices for replacement injectors.
Old Jan 6, 2004 | 01:02 PM
abeaujuin's Avatar
Default Re: Acura Legend Injectors (twkdCD595)
My car stumbles when I attempt to take off. As if it is hesitating. It is very difficult to get up a hill without reving it. I have changed everything that needs to be changed for a tune up, but I still don't have any power. I noticed that sometimes when I start the car after driving aggresively, the idle is low for a second and then is idles back to normal. I am thinking maybe the injectors are bad.
Old Jan 6, 2004 | 01:11 PM
p0pe's Avatar
Try some BG44K professional strength fuel system cleaner first. Used at dealers for tune ups, etc. Works great... before I ran it through it would idle rough and the injectors were noisy as hell. Now it runs a lot smoother and no more stumbling idle.
http://www.ec-securehost.com/R....html
Old Jan 6, 2004 | 01:14 PM
abeaujuin's Avatar
Default Re: Acura Legend Injectors (p0pe)
Can I possibaly get it locally?
Old Jan 6, 2004 | 01:17 PM
abeaujuin's Avatar
Does this sound like a fuel injector problem?
Old Jan 6, 2004 | 01:23 PM
p0pe's Avatar
Some dealerships & NAPA stores carry it... I couldn't find it locally though. It may be an injector problem but could also be your clutch, how old is it?
Old Jan 6, 2004 | 01:26 PM
abeaujuin's Avatar
clutch is new. Clutch Masters stage II. I noticed when the car is cold, it idles at 1,500 RPM. If I drive it then I have power. I can peel out and everything, but when it warms up and start to idle normal I have no power to move off.
Old Jan 6, 2004 | 07:11 PM
iam7head's Avatar
i would invest in four bange new injectors, especailly with the legend dated 10 years.
a failed injector can SCREW you up, bad
Old Jan 6, 2004 | 07:19 PM
abeaujuin's Avatar
Default Re: Acura Legend Injectors (iam7head)
I just install 4 new injecters. same problem could it be the tranny? I even have touble getting the gear in first at times.
Old Jan 6, 2004 | 07:52 PM
RotaryBzzzz's Avatar
fyi - clutchmaster clutches are "rebuilt", not new Though i still think its injector related...
Old Jan 6, 2004 | 07:58 PM
abeaujuin's Avatar
Default Re: Acura Legend Injectors (RotaryBzzzz)
I thank you for your help, I am taking the car to a Performance Tuning shop tomorrow, if they can't tell me what the problem is I am getting ride of this car. I have spend too much money on it already.
Charlie Moua
Jul 25, 2013 04:34 AM
dantamparacer
Nov 11, 2009 06:25 PM
J-Spec EG
Apr 27, 2004 05:40 AM
SpeedMonkeyRacing
Sep 7, 2002 08:13 AM
93B17A
Mar 11, 2002 12:29 PM
