Adj. Timing belt tension w/engine in car?
Old Jan 6, 2004 | 11:24 AM
RacerZook's Avatar
Default Adj. Timing belt tension w/engine in car?
Just want to make sure this can be done with the engine in the car (2001 GSR). Any tips on how to do it like how to get to the bolts?
Thanks
Old Jan 6, 2004 | 12:06 PM
IN VTEC's Avatar
Default Re: Adj. Timing belt tension w/engine in car? (RacerZook)
You can do it.
Use a 3/8" drive 14mm shallow socket.
May need a cheater bar (3/8" drive 19mm deep socket on a 9" extension) b/c it's pretty hard to break it loose the first time.
You shouldn't need to remove the PS belt or the driver-side upper mount. Altho, I can't really remember if it makes it easier or not to loosen the tensioner bolt. I end up always removing them to have room to work and get the crank pulley off.
AudioFunk
Mar 7, 2014 09:16 PM
MinimusMaximus
Sep 22, 2011 07:19 AM
cvc1393
Jun 25, 2009 07:07 PM
thedao
May 9, 2008 08:47 AM
dbailey
17
Mar 19, 2008 03:54 PM
