Forged Piston noise after install....
Old Jan 6, 2004 | 10:53 AM
ChillOutWayne's Avatar
Default Forged Piston noise after install....
I got my block back from the machine shop two days ago and began to piece everything together, and i finished last night. I put 30 miles on the motor and it sounds slightly like a diesel engine, not that loud but louder than stock. i know that forged pistons usually rattle a little during warmup but even after its warm it does the same thing, again not rediculously loud just noticeable, wat u guys think?
btw i got a 94 GSR with CP 9:1 pistons and Eagle H-beam rods, NO boost yet, just na for a about 2 months...thanx in advance
Old Jan 6, 2004 | 12:33 PM
i got a feeling this is bad news
Old Jan 6, 2004 | 12:52 PM
Zimmlude's Avatar
Did you sleeve the block? I have heard that forged pistons do not work in the stock FRM sleeves. I am by no means an expert but that's what I have heard.
Old Jan 6, 2004 | 12:59 PM
bloopie's Avatar
Default Re: (Zimmlude)
Check your valve clearance! Sounds like you need an adjustment!
Old Jan 6, 2004 | 05:02 PM
i know it aint the valves, i had a slight valve click before, this is more like a diesel motor sound, or a rod knock
Old Jan 6, 2004 | 08:32 PM
any other thoughts?
Old Jan 6, 2004 | 09:00 PM
IN VTEC's Avatar
Default Re: Forged Piston noise after install.... (ChillOutWayne)
I'd suspect the clearances being too loose. Does it smoke any?
I'll post up a vid and some pictures of an improperly clearanced block with 2618 alloys.
Old Jan 6, 2004 | 09:21 PM
turtle-eg's Avatar
Mostly likely it's piston slap. My engine does the same thing and I have put about 4500 miles on it with no problems it, even NOSed it a couple of times. What kind of machine shop did the work on the block, do they do high performance stuff or just regular rebuilds? If they do regular stuff(which is the kind I used!), then more than likely they machined the bore too big.
Old Jan 6, 2004 | 10:12 PM
RA166E's Avatar
I'm running a JG Engine Dynamics Pro Series D16Z6 with Arias pistons.
It has alot of piston slap noise. Its been this way since it was new. It has about 8000 miles on it and know problems. Did a leak down and compression test on it this fall and everything looks great.
Old Jan 6, 2004 | 11:10 PM
thanx for the replies guys...yea i got a bad feeling its slap too, i talked to the guy today and he said that even tho the pistons are oversized for a 81.5mm bore, the sheet that came with them claimed a 3.209 bore, which is larger than 81.5, at least thats wat he said, so he claims he went to 3.206 with the bore then 3 thousands more off with the honing. he said to check oil press. ect and let him know, im doing a valve adjustment tomorrow also...any other thoughts would be great
p.s wat kind of compression #s should i be pulling with 9:1 os and a fresh bore?
Old Jan 6, 2004 | 11:58 PM
aeolus's Avatar
Default Re: (ChillOutWayne)
close to 180 psi after 7-8 strokes.i wonder once you get the turbo on,the engine may quit down a little,those pistons were made for turbo,so you may not have enough heat to have them expand to the size they are supposed to be.
Old Jan 7, 2004 | 08:06 AM
crxluv2's Avatar
Default Re: (aeolus)
When my maching was done I gave them the pistons with the block to make sure they got it right. Make sure you do the compression test by the book.
Old Jan 7, 2004 | 08:21 AM
IN VTEC's Avatar
Default Re: Forged Piston noise after install.... (IN VTEC)
I think he rebuilt the motor with those pistons back in NY two years prior to when I got to know him and before he was my roommate. The build had like 10k-11k miles on it by the time we took it apart.
Nov 2002 - Compression test on the motor was 260psi all the way across.
March 31st, 2003 - Dyno Day
7.1MB AVI - My roommate's car at idle.
http://portfolio.iu.edu/bchang...I.AVI
1.9MB AVI - Getting rolling on the dyno
Dyno plog:
Oct 2003 - What started as replacing a head gasket, turned into rebuilding the motor. Up to the end, the motor never smoked. Ring sealing was just fine.
Forged pistons, esp 2618 alloy slugs, are supposed to wear the bore, but I don't think this level of wear is normal unless the installation was faulty.
From the looks of things, the pistons were probably in there too tight.
Other info: The pistons were never clearanced in according to him. I'm not even sure that the bores were even honed if that gives you an idea of the level of carelessness the motor was put together with.
I'm pretty sure the JUN pistons are 2618 alloy, but I wouldn't quote me on that.
Old Jan 7, 2004 | 08:24 AM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zimmlude &raquo;</TD></TR><TR><TD CLASS="quote">Did you sleeve the block? I have heard that forged pistons do not work in the stock FRM sleeves. I am by no means an expert but that's what I have heard.</TD></TR></TABLE>
If he had the coating on his cylinder walls that would be true but that isn't a prelude.
Old Jan 7, 2004 | 09:04 AM
yea im kinda wondering the same thing. i had a guy around here who works on hondas and stuff take a look at it and he said that it seems normal to him and im paranoid and that it even sounds a little like detonation? anyway the car runs good and like i said i talked to the machine guy and he said to drive it and he will look at it, so i will drive it and if it takes a ****, then he will pay for the rebuild...thanx for the info and thoughts guys, keep em coming
Old Jan 7, 2004 | 09:06 AM
wow, i just listened to that video and that is definetly a whole lot louder than mine, in fact unless the motor is right at 750rpms, its hard to hear outside the car, but inside u can pick it up even thru light acceleration up to 3k or so....
Old Jan 7, 2004 | 09:22 AM
PhatOptimo's Avatar
Forged pistons require more piston to cyl wall clearance than OEm pistons. Forged pistons expand when they get hot thats why the cpiston to cly wall is sert higher. If you don't have the piston to cyl wall clearances correct then you take a chance a seizing the pistons like the pics above show. You can also seize a piston if you spin forged pistons up high before they swell to operating temp. Its hard to say what the problem is but if you can find out what the piston to cyl wall clearance was it would help determine if that could be a problem. Hopefully you gave the machinest the spcs before he installed them.
Old Jan 7, 2004 | 10:10 AM
all i know is that he recieved the block and new pistons/rods/bearings ect. before doin any machining...the spec sheet that came with the pistons called for the final bore to be 3.209 and he bored to 3.206 and honed an additional 3thousands out to get the final bore, he also said u need at least 5 thousands overbore to achieve a pistons slap, who knows...im hoping thats not it, we will see
Old Jan 7, 2004 | 10:41 AM
senpai's Avatar
Did you give the machineshop the pistons and block? That way they can bore it correctly with whatever piston-cylinder wall clearance you want. I had put .0035" (WISECO) and I think I should have went lower because the diesel sound sucks.
Old Jan 7, 2004 | 11:08 AM
oh u got the diesel sound too? when does it happen? at idle? when its warm is it there too? how long have u had that?
Old Jan 7, 2004 | 03:58 PM
the weird part is when i start the car and the revs are at about 1500 or so i cant hear the diesel sound hardly at all, it isnt until the motor warms up and the idle drops down and then i can hear it, again, mostly just from in the car
Old Jan 7, 2004 | 05:07 PM
Jim Truett's Avatar
What kind of bearings did you use, and what were the clearances?
Old Jan 7, 2004 | 05:50 PM
D-Man's Avatar
could be your fuel injectors,some aftermarket injectors are alittle noisy like RCs rotary type.
Old Jan 7, 2004 | 07:54 PM
ScottFern's Avatar
stock fuel injectors and i used ACL rod bearings and ACL thrust washers, i used Federal Mogul main bearings, he said all the clearances were in spec on those so who knows
Old Jan 7, 2004 | 07:55 PM
ScottFern's Avatar
sorry im on my buddies name and cant get it to log out, this is ChillOutWayne
