JDM final drive
Old Sep 26, 2001 | 09:20 PM
DelsolVtec18's Avatar
New User
Default JDM final drive
Dumb question??? What is a JDM final drive
Old Sep 26, 2001 | 09:24 PM
Chris's Avatar
Default Re: JDM final drive (DelsolVtec18)
In Japan they use a shorter gear ratio, due to the use of 16" wheels (On USDM cars...they will rev higher).
Think of the Final Drive as the FRONT sprocket on a 10 speed...and 1-5th gear as the REAR sproket.
Old Sep 27, 2001 | 03:45 AM
2k1TypeR0610's Avatar
New User
Default Re: JDM final drive (Chris)
I've heard this remark before. But the final drive was done in JDM version of the type R much for the same reason there was no a/c in the first Type Rs made. To make it more performance oriented. Just becuase the rims are bigger is of no consequence. They are running lower profile higher performance tires(205/45/16); therefore, the circumference of the tires remains the same as ours(195/55/15). Everything since the conception of the car in Japan was aimed at providing performance not comfort. Therefore the different final drive provides higher engine speeds coming out of an apex of a turn and quicker acceleration.
Old Sep 27, 2001 | 04:41 AM
austrian type-R's Avatar
Re: JDM final drive (DelsolVtec18) (Chris)
Completly false!!!!!!!!!!!!!!!!! It has NOTHING to do woth 16inch rims. They have 16inchers, but also a thinner sidewall of the rubber so the diameter of the tire itself is the same. The EURO ITR has also the JDM final drive and use 15 inch rims with 195/55/15 rubber (595mm diameter).
BigAl
Jun 4, 2002 06:48 AM
DelsolVtec18
Sep 29, 2001 11:00 AM
DelsolVtec18
Sep 27, 2001 01:14 AM
DelsolVtec18
Sep 26, 2001 09:52 PM
