===== how do tell if its an OBDI or OBDII? ============
the plugs are different...you cant plug a OBDII ecu into a 94-95 gsr and vice-versa you cant plug a OBDI ecu into a 96-up gsr...unless you have a wire harness adapter.
Like DelSolVtec18 said, check the plugs on the ECU:
Here's an image the OBDI plugs:
and here is an image the OBDII ecu plugs:
hope that worked and helped,
/T
BTW - these giffs are directly from the 5G and 6G tech pages of the Hybrid board @ http://hybrid.honda-perf.org
[Modified by T_Sem, 1:14 PM 9/27/2001]
/T
