can you clean the top of the pistons?
Old Jan 5, 2004 | 09:34 PM
hondaeg8's Avatar
Default can you clean the top of the pistons?
my friend is about to change his headgasket and was wondering if you could clean the top of the pistons when the head is off? we won't see the pistons until he takes his head off, but if they have carbon build up, could he use something to take it off the pistons?
Old Jan 6, 2004 | 01:46 PM
hondaeg8's Avatar
Default Re: can you clean the top of the pistons? (stockhatch)
bump up
Old Jan 6, 2004 | 02:02 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
If you're not going to bother taking them out of the block to clean them then I definitely wouldn't do it.
PM-Performance's Avatar
yea i used brake cleaner and like wet sand sanding paper and shined everything up all nice and cleaned em up
Old Jan 6, 2004 | 02:12 PM
Atheist's Avatar
didnt that create a hot spot itr?
Old Jan 6, 2004 | 02:16 PM
alloutmotor's Avatar
you could..but a little carbon isnt bad...just a little extra compression
Old Jan 6, 2004 | 05:08 PM
Default Re: (Atheist)
a hot spot? not if you do the whole piston. the engine builder does that to your pistons when he builds it anyway its fine, just dont go overboard.
and it really isnt good to have build up , becuase then if you get uneven build up on each cyl, youll have diff compressions which might not make too much of a difference, but id rather know its done.
sk8board{Pete}
Oct 19, 2008 12:07 PM
EK FLY
Jan 31, 2006 05:42 PM
sshaikh01
May 20, 2003 05:45 PM
KayOs
Oct 4, 2001 10:12 PM
