So tell me about the CRV AWD system
Does the CRV AWD system have an external transfer case that handles all the rerouting of the power?
If so where is it located? Is it mounted on the back of the block? Does it intercept the intermediate shaft?
Also this is not a 'full-time' AWD is it? It just kicks in when it slips right?
Thanks in advance
Thanks in advance
I don't know the answers to your question, but the people at http://www.hondasuv.com might. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">Does the CRV AWD system have an external transfer case that handles all the rerouting of the power?
Thanks in advance</TD></TR></TABLE>
yea the realtime 4wd activates due to a differential that transfers tq to the rear when the front slips. in my opinino, its pretty handy in rain/snow/ice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azndng »</TD></TR><TR><TD CLASS="quote">
yea the realtime 4wd activates due to a differential that transfers tq to the rear when the front slips. in my opinino, its pretty handy in rain/snow/ice.</TD></TR></TABLE>
it's AWD, not 4WD, get it right, it's not the samething
oh it is quite nice (though i have an element...same system as the CRV).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Real Time™ 4WD
The Real Time™ 4WD system on the CR-V is designed to overcome the traditional drawbacks of a full-time four-wheel-drive system such as lower fuel economy, higher noise and vibration levels, higher weight and difficulty in adapting the system to ABS. The CR-V’s Real Time™ 4WD operates automatically and only when needed. It requires absolutely no intervention on behalf of the driver for it to be engaged or disengaged.
The CR-V’s Real Time™ 4WD system sends power only to the rear wheels when there is insufficient traction for the front-wheel-drive system. The system consists of the conventional front-wheel-drive system, a compact transfer case that distributes drive to a propeller shaft running the length of the vehicle, a dual-pump system, the rear differential, and left and right rear-wheel driveshafts.
The heart of the system is the dual-pump unit. It consists of two hydraulic pumps, one driven by the front wheels via the propeller shaft and one driven by the rear wheels via the rear differential. A hydraulically actuated, multi-plate clutch, similar to the clutches used in Honda automatic transmissions, connects the propeller shaft to the rear differential.
When the CR-V is operating with the front and rear wheels turning at the same speed, for example on dry pavement, the front and rear hydraulic pumps operate at the same speed. Hydraulic fluid circulates between the two pumps; however, no pressure is generated. In effect, the fluid fed by the front pump is absorbed by the rear pump.
If the front wheels begin to turn faster than the rear wheels, as would be the case if they were spinning on snow or ice, the two hydraulic pumps would turn at a different rate and hydraulic pressure proportional to the difference in their speeds of rotation would be generated. The resulting hydraulic pressure opens a valve body and feeds pressure to the multi-plate clutch, which engages the front propeller shaft to the rear differential. The rear differential feeds the drive torque to the right and left rear wheels.
System operation is completely automatic; no electronics or driver action is involved. The greater the degree of front-wheel slippage, the greater the amount of torque fed to the rear wheels. Real Time™ 4WD is also practically maintenance- free, requiring only a scheduled fluid change at 96,000 km or 48 months under severe conditions. Another big advantage of the CR-V’s dual-pump Real Time™ 4WD system is that, unlike conventional 4WD systems, Real Time™ 4WD automatically disengages under braking, thereby allowing the ABS system to engage.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">
it's AWD, not 4WD, get it right, it's not the samething</TD></TR></TABLE>
refer to pic
refer to pic
I know in the pilot that it is possible to switch the drive system so it is always in 4 wheel drive but in the crv's and element's system it is activated by the front tires spinning to activate the rear wheels.
kingrat
Dec 1, 2003 08:16 AM
