VAFC WITH A 3 BAR MAP?? HELP! will it work?
Old Jan 5, 2004 | 04:20 PM
D@nnY's Avatar
Default VAFC WITH A 3 BAR MAP?? HELP! will it work?
I have hondata with a 3 bar map. I was just thinking about how the vafc modifies the map signal on a stock map sensor. Now the gm 3 bar map has a completely different voltage than a honda map. woul i still be able to tune the fuel curve with the 3 bar and vafc?on top of the hondata? god damn this is a wierd one...help-thanks
Old Jan 5, 2004 | 04:27 PM
spoolinlude's Avatar
I live under a rock
Default Re: VAFC WITH A 3 BAR MAP?? HELP! will it work? (GSRT37)
you have hondata? what the hell are you running a vafc for????
Old Jan 5, 2004 | 04:36 PM
B18bEK's Avatar
Default Re: VAFC WITH A 3 BAR MAP?? HELP! will it work? (spoolinlude)
^^what he said ... you have Hondata .. whats the vafc for?
Old Jan 5, 2004 | 04:58 PM
Del_Slowest's Avatar
Default Re: VAFC WITH A 3 BAR MAP?? HELP! will it work? (B18bEK)
so he won't have to take it to a dyno i assume......
Old Jan 5, 2004 | 05:13 PM
T-RO's Avatar
Is it really a good idea to run 11+psi and NOT go to a Dyno?
Old Jan 5, 2004 | 05:46 PM
D@nnY's Avatar
I have no money at all for dyno tunning. things came up had to pay traffic tickets owed people money. **** broke on the car. I had the vafc before I was turbo. The hondata was bopught used tuned for 756 cc injectors and a 3 bar map on the same setup as me but i have 880s. so i figured i could lean it out a little but now that i think about it it doesnt make sense..
Old Jan 5, 2004 | 05:48 PM
D@nnY's Avatar
the car is set a 4 pounds and i dont take it into boost when i did it runs fine in lower rpms but at like 6500 rpm it starts breaking up...
Old Jan 6, 2004 | 06:19 AM
Default Re: (GSRT37)
if you have hondata then you can use the vafc to tune on top of hondata. there is another thread on here about a kid doing it.
https://honda-tech.com/zerothread?id=723038
he's having problems with the car studdering but it's prolly his plugs.....silly bastard isn't using ngk 2 colder
Old Jan 6, 2004 | 09:11 AM
yimmy's Avatar
Default Re: (Del_Slowest)
Why dont you just sell the vafc
Old Jan 6, 2004 | 09:53 AM
flip1199's Avatar
Default Re: (yimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you just sell the vafc </TD></TR></TABLE>
Exactly, just sell the vafc to get money for some dyno time...
Old Jan 6, 2004 | 05:08 PM
I live under a rock
Default Re: (flip1199)
There is NO POINT in having hondata and an AFC....... at all... an afc improving a hondata is also never going to happen.... get the afc off there, use a hondata basemap and wait till you can get dyno time...... my car was 1year in the making blew up 3 months after finish(blew up in June), and now has a fully built motor in pieces..... a lil patience won't kill you
JDM97R
Jul 22, 2008 09:27 PM
JDM97R
Jul 20, 2008 11:29 PM
TurboB15sentra
Jan 30, 2006 01:32 PM
redboost10
Apr 5, 2004 03:56 PM
filetofit
Jul 4, 2002 01:49 PM
