If i just bought a 88 teg ecu from someone from this site, what should it say on it PM6 or PM7?
Old Jan 5, 2004 | 03:45 PM
Wes90civic's Avatar
Default If i just bought a 88 teg ecu from someone from this site, what should it say on it PM6 or PM7?
Well i think i got ripped cause i paid for a ecu from a 88 teg, and i thought that was a pm7 well, i looked on the casing and it says 88/2/15 which is year and date, but then it says PM6, i think i got ripped. So can anyone help with my question.
Old Jan 5, 2004 | 03:46 PM
Tyson's Avatar
Default Re: If i just bought a 88 teg ecu from someone from this site, what should it say on it PM6 or PM7?
pm6 is Si. p-G-7 is integra. PM7 is HF i believe.
ECU casing is very different on PG7, although the internals can be swapped into PM6 casing perfectly. serial code is attached to the board not the casing in case there may be any confusion.
Old Jan 5, 2004 | 04:08 PM
Ronin Panda's Avatar
PM6=U.S Si
PG7=U.S 1st gen Integra
PM7=JDM Si (ZC)
Old Jan 5, 2004 | 04:27 PM
Wes90civic's Avatar
Nevermind he just put the PG7 in a PM6 case, he just forgot to tell me that, lol, i thought i got ripped.
Old Jan 5, 2004 | 05:09 PM
subgeniusdude's Avatar
Default Re: (Wes90civic)
Are you sure ? I tried putting a PG7 into a PM6 case and it wouldn't fit... the PG7 and PM6 case are not only different (PG7 has 3 mounting legs on it instead of 4),but the circuit board of the PG7 is physically bigger than the PM6/PM7 making it impossible to swap out...I've heard of it being done,and if anyones been ballsy enough to take a Dremel to their circuit board and ghetto rig it in there,then I'd like to see it You can swap the internals of a PM6 to a PM7 case and vica versa though.
Old Jan 5, 2004 | 06:40 PM
91civicDXdude's Avatar
the 88-89 PG7 and 88-91 PM6 and 88-91 PM8 (HF) all share the same case. PM5, PM9, and the 86-87 PG7 have different cases and board sizes and will not fit into the PM6 case.
Old Jan 5, 2004 | 07:10 PM
davens's Avatar
Default Re: (91civicDXdude)
Hmm...I wonder why the two 88-89 pg7 teg ecus I pulled out of the junkyard have the three leg mounting points and all the pm6, pm5 ecus I've seen have four legs...maybe because they're different?
Old Jan 5, 2004 | 07:38 PM
the case is differnt dumbass. the board is the same size and has the same mounting points.
PM6 = PG7 = PM8
by the same, i meant that they will all interchange cases.
Old Jan 5, 2004 | 07:42 PM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">the 88-89 PG7 and 88-91 PM6 and 88-91 PM8 (HF) all share the same case.</TD></TR></TABLE>
Your words, not mine "dumbass".
Old Jan 5, 2004 | 11:29 PM
Tyson's Avatar
sorry, i was wrong, PM-EIGHT is the HF ecu. i just remember it was greater than Six.
PG7 fits fine in PM6 casing, ive done it fine. casings are very different in dimensions however.
Old Jan 6, 2004 | 09:55 AM
Default Re: (Tyson)
86-87 PG7 internals wont fit into a PM6 case,but 88-89 internals will from what I just learned.I had a 86-87 and couldn't fit it into the PM6 case.
Old Jan 6, 2004 | 11:49 AM
virginia_dude's Avatar
PM5 is DX
PM6 is Si
PG& is Integra
PM7 is JDM ECU for ZC
driftam1
Oct 27, 2008 02:43 PM
It's*BOLO!!
Jan 5, 2003 11:23 AM
Red_Si
Jul 11, 2002 07:34 AM
USDM 4G VTEC
May 13, 2002 06:00 AM
USDM 4G VTEC
May 13, 2002 05:59 AM
