surging idle and bucking throttle after swap in EK
Old Jan 5, 2004 | 03:25 PM
743power's Avatar
Default surging idle and bucking throttle after swap in EK
https://honda-tech.com/zerothread?id=723770
Old Jan 11, 2004 | 10:26 AM
743power's Avatar
Default Re: surging idle and bucking throttle after swap in EK (743)
bump
Old Jan 11, 2004 | 11:38 AM
TeamNextGenChris's Avatar
are cam timing and igntion timing in spec?
chris
Old Jan 11, 2004 | 12:55 PM
s2kintegra's Avatar
The fact that you keep getting different cel codes makes me wonder about the wire harness??? I would suspect an IM gasket for the idle.
Old Jan 11, 2004 | 02:49 PM
743power's Avatar
Default Re: surging idle and bucking throttle after swap in EK (s2kintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kintegra &raquo;</TD></TR><TR><TD CLASS="quote">The fact that you keep getting different cel codes makes me wonder about the wire harness??? I would suspect an IM gasket for the idle.</TD></TR></TABLE>
We dont get different CEL's. We had one for the secondary o2 sensor, and it went away when we installed the cat. We have a 91 for the fuel tank sensor, which cx's dont have. We got a 14 for the IACV when it was disconnected, but that went away when the IACV was hooked up.
743power
Jan 23, 2011 05:47 PM
stkinge
12
Jun 10, 2010 09:31 PM
juzthewy
Feb 5, 2008 04:34 AM
ekjdmgsr
Nov 6, 2007 06:46 AM
pyromaster
Apr 7, 2005 11:03 AM
