not reving
i jstu swapped my 90 dx to mpfi and got all the wirign right i though, engine runs fine exept that when its running it wont rev past 3500 ?? throwign code 4 which is the crank angle sensor, would timing affect this?? distributor is genuine honda parts 2 weeks old any ideas??
same thing happened to me, their are 2 wires that you cut for the Cyl. Position sensor (the one in the dizzy, not the crank angle sensor) they need to be hooked back up into B10 and B12, that will cure your problem
edit: the light colored one goes to B10, cant remember the exact color
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey »</TD></TR><TR><TD CLASS="quote">check the wiring on the dizzy. Maybe you swaped wires by mistake?</TD></TR></TABLE>
Did you not feel like answering my question? The problem is in your wiring.
on the ecu's center plug, the B plug, pins 10 and 12
thank FourthGenHatch.com for the pic
edit, the white wire goes to B12 and the Orange to B10
hey man thanks i appreciate that, ill certainly look at all my wiring when i get home i should be off here bout another 10 minutes and ill recheck that stuff, ill keep ya informed
mugenwannabe
Jan 22, 2004 12:52 PM
streetdreams420
10
Aug 13, 2003 02:15 PM
