i cant take my axle nutt off eh! someone help!
Old Jan 5, 2004 | 02:38 PM
gsrcivic619's Avatar
Default i cant take my axle nutt off eh! someone help!
i got my axle nut put on with air tools and i dont have air tools and i need to take my axle nutt off. i've already tried a cheater bar and it aint working, im like stripping the bolt and the bolt aint budging. is there any tips or any easy ways to take off an axle nutt? thanx
Old Jan 5, 2004 | 02:42 PM
=GAME='s Avatar
Default Re: i cant take my axle nutt off eh! someone help! (gsrcivic619)
hope this help. https://honda-tech.com/zerothread?id=606866
Old Jan 5, 2004 | 02:51 PM
NVturbo's Avatar
O.G. triple O.G.
You are using a "32mm" axle socket...aren't u? One trick i learned is to use the floor jack stick and slide it over the breaker bar. Make sure the breaker bar is at least 18" long cause it has more leverage. Have a friend hold the socket in place while you "walk" the bar to loosen it...If the breaker bar breaks (trust me,it has) get another one. This should do the trick!!!
Old Jan 5, 2004 | 02:54 PM
Happyman's Avatar
Default Re: i cant take my axle nutt off eh! someone help! (NVturbo)
Or just get any ratchet with 32mm nut and take like a 19mm wrench and use it to extend the handle of the ratchet. That's what I did when I had to brake the axle nut lose on my shizzle.
Old Jan 5, 2004 | 02:57 PM
EG-lowrider's Avatar
been there, do the jack handle trick , if you break a few sockets and breaker bars like i did, take a torch to it and get it red hot, then try it, worked for me,, good luck.
Old Jan 5, 2004 | 02:58 PM
redlinetuning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">You are using a "32mm" axle socket...aren't u? One trick i learned is to use the floor jack stick and slide it over the breaker bar. Make sure the breaker bar is at least 18" long cause it has more leverage. Have a friend hold the socket in place while you "walk" the bar to loosen it...If the breaker bar breaks (trust me,it has) get another one. This should do the trick!!! </TD></TR></TABLE>
you also need to have someone on the brake pedal.. and just make sure you're turning the nut counter-clock wise??? that might help.
Old Jan 5, 2004 | 02:59 PM
PhucNguyen57's Avatar
While the car is on the ground, pop out the center cap. Behind it you should see you axle nut. Put your socket on the nut and give your breaker bar short bursts of enegry until the nut is loose. It works every time
Old Jan 5, 2004 | 03:01 PM
thanx guys i think i stripped the axle nutt not sure though..... but i think im gonna have my friend take my *** to home depot and buy a propane torch thingy see if that **** works.... how long do i torch it for? or how does that work?
Old Jan 5, 2004 | 03:03 PM
Black Armada of Death's Avatar
In fact, any steel pipe that will extend the length of the breaker will work.
Did you try using penetrating oil yet? I use Silikroil made by Kano Industries I beleive.
If you round off the nut, you going to end up cutting it off so be careful, and make sure you're on square before applying pressure.
Happyman's Avatar
Default Re: (gsrcivic619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivic619 &raquo;</TD></TR><TR><TD CLASS="quote">thanx guys i think i stripped the axle nutt not sure though..... but i think im gonna have my friend take my *** to home depot and buy a propane torch thingy see if that **** works.... how long do i torch it for? or how does that work?</TD></TR></TABLE>
Torch it til it gets red hot. Don't worry about stripped the nut you get a new one with the new axle anyway. Heat it, and channel lock that biatch.
Old Jan 5, 2004 | 04:07 PM
civic_tuner's Avatar
Default Re: (Happyman)
if you did strip it, try a pipe wrench. that might work. good luck
butter99
21
Nov 27, 2008 09:00 PM
mondo375
Jun 1, 2008 01:50 PM
ricerodder91EX
33
Apr 14, 2007 12:24 PM
Mr.Meowsome
38
Nov 25, 2006 04:33 PM
brent_G
Apr 26, 2002 11:18 AM
