what would cause this, need help asap
well my brother put 92-95 civic si rear disks and suspension on his 89 crx si and when we took it on the roads the back end would kick out all the time and when we hit a small patch of ice the whole back end would go all crazy, any help please
The 89 did not have disk brakes right? If that is in fact true the master cylinder is set up for disk front and drum rear. You will have to change out the master cylinder for disk all around. It is sending to much pressure to the rear and they are probably locking up.
Just a guess, hope it helps.
what we are thinking is that we never got a wheel alignment after because we did use the whole back end of that car almost so we are going to try a 4 wheel alignment done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">what we are thinking is that we never got a wheel alignment after because we did use the whole back end of that car almost so we are going to try a 4 wheel alignment done</TD></TR></TABLE>
huh?.. some one translate...
You did not get an alignment because you used the entire back end?
But now you are going to get a 4 wheel alignment?
88YellowRexSi
Sep 19, 2006 01:03 PM
