D15B7 W/ D16Y8 Head, Which Timing Belt??
im doin a mini-me swap and the timing belt we have has a shitload of slack, which timing belt are you supposted to use with the B7/Y8- Block/Head Combo?
i dont see what the difference would be between the vtec and non vtec head to make the necessary t-belt different. shouldn't the only things that matter be the water pump and the deck height?!?
-Bryan-
-Bryan-
The B7 head and Z6 heads are completely different designs...the B7 head stands a little bit taller than the Z6. Not to mention B7 and Z6 dizzys ARENT interchangable. The Y7 and Y8 heads are closer to the Z6 than the B7...all sharing the same t-belt as well as having the plug wires in the front...also the Y7 and Y8 share the same distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff »</TD></TR><TR><TD CLASS="quote">you should get the timing belt to match whichever head is on the engine
Is that also true for b-series? A friend of mine has a b16 block and b18 head. Should he be using a b18 belt?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKRacer »</TD></TR><TR><TD CLASS="quote">
Is that also true for b-series? A friend of mine has a b16 block and b18 head. Should he be using a b18 belt?</TD></TR></TABLE>
Not sure about B-series...
i've got a question
i'm riding with a y7
would adding a z6 head mean that i would have to change the dizzy? anything else?
would it be easier to add a y8 head? or "better"?
down the line, I'll probably be adding some pistons. I want my comp around or slightly under 12:1, just gotta find some a1 pistons
Y8. Z6 has a different dizzy than Y7 and Y8...and the whole OBD1 conversion thing would be a pain in the ***...get a Y8 head and u can use the Y7 dizzy, IM, header etc...you'll need to get the EX ecu and then wire up the VTEC and knock sensor
yrulkn@me
Jul 2, 2007 01:08 AM
lohatch
Jun 15, 2004 07:44 AM
