what do i use
Old Jan 5, 2004 | 01:05 PM
FAST AS's Avatar
Default what do i use
i need to get the pins out of the harness plugs what do i use:honda2:
Old Jan 5, 2004 | 01:08 PM
RCautoworks's Avatar
Default Re: what do i use (FAST AS)
You could use the Honda tool, if you can find it. Or goto a eye glass store and get a mini screw driver. Or you could goto harborfreight.com and order this.
Or you can try going to like a dollar store and buying a set of cheap mini screw drivers. Or you can try to grind down the tip of a nail and use that. Or you can try to use a heavy duty staple. Hope that helps.
Old Jan 5, 2004 | 01:12 PM
FAST AS's Avatar
Default Re: what do i use (90blackcrx)
thanks
Old Jan 5, 2004 | 04:27 PM
BAZ's Avatar
BAZ
I use a bobby-pin. (roachclip) haha!
Old Jan 5, 2004 | 04:52 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I used a dental pick..
Make sure you have the retainer out (white comb looking thing)
I put the plug in a vise so I could release the pin while slightly tugging on the wire.
It is a pain to get the technique down so be patient.
right click and select show picture or click here if pic does not show..
Old Jan 5, 2004 | 04:56 PM
EL Vap133's Avatar
Default Re: what do i use (88DXCRX)
Very nice! Where did you get that dental pic at Phil?
Old Jan 5, 2004 | 05:23 PM
Default Re: what do i use (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Very nice! Where did you get that dental pic at Phil?</TD></TR></TABLE>
Probably not where Phil got it from but you can get them at harborfreight.com
http://www.harborfreight.com/c...34151
Old Jan 5, 2004 | 06:58 PM
blah13's Avatar
I'd check any grocery/drug store. I used a sewing needle (not fun)
Old Jan 5, 2004 | 08:35 PM
crashtest Sonny's Avatar
wow you actually cut out the plug and do it on a table? then you have to wiring it all up again? what hassle! i just did it right there in front of the ecu! i used a tweezer..
Old Jan 6, 2004 | 12:28 PM
Default Re: what do i use (crashtest Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashtest Sonny &raquo;</TD></TR><TR><TD CLASS="quote">wow you actually cut out the plug and do it on a table? then you have to wiring it all up again? what hassle! i just did it right there in front of the ecu! i used a tweezer..</TD></TR></TABLE>
It actually could be spare plug, I have some laying around just in case I mess up some clips.
Old Jan 6, 2004 | 02:13 PM
88DXCRX's Avatar
Hey Vap,
I got that at a "True Value" hardware store..
The plugs were in the ecu that came with my swap..
Old Jan 6, 2004 | 02:18 PM
EL Vap133's Avatar
Right on Phil!
JDMCRX
Jul 9, 2009 12:38 PM
dave@passenger
Welding / Fabrication
Apr 18, 2007 10:41 PM
00b18b
Oct 5, 2001 05:13 PM
