lsvtec at 10psi
I can't say how much HP 10 PSI would dyno at. There are alot of variables you must take into consideration ie.. built or stock, head, compression, turbo. I do have an LS/vtec turbo and when I dynoed it at7 psi I made 268, and I was running 13.1-12.8. I turned the boost up to 9.5 and I was running 12.0-11.9.
The engine was a stock block, stock b16 head with a 57 trim t3/t4 turbo and 2.5 downpipe. Ran like a champ till I boosted to 20psi by accident and blew the ringlands out.
kinda wondering too cause im buliding an ls/vtec also for boost. I got a gsr head, forged pistons/rods and gonna run a sc34 at like 15psi max!!! Hopefully everything will work out. I want to get like 350 whp!! More would be nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8turbolsvtec »</TD></TR><TR><TD CLASS="quote">how hp will a lsvtec make at 10 psi ?
If a monkey flew outta ur *** how bad would it hurt ?
well how big is the monkey?, how big is your ***?
Theres WAY too many varibles to anwser that question in short.
To better the knowledge your looking for would be to do a search. To find specfics
do some more reasearch.
</TD></TR></TABLE>If a monkey flew outta ur *** how bad would it hurt ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb »</TD></TR><TR><TD CLASS="quote">
do some more reasearch. </TD></TR></TABLE> you like monkeys coming out of your *** hahahahahahahaha
this is you when it happends
this is you when it happendsTrending Topics
Topdawgg
Feb 17, 2006 10:20 PM
