Rear disk brakes on 91 hatch
Old Jan 5, 2004 | 10:46 AM
charjacq's Avatar
New User
Default Rear disk brakes on 91 hatch
I have recently swapped my rear drums for disk brakes. I know 90-01 integra rear control arms should all fit nicely on a 88-91 hatch. I believe I have JDM 94+ integra rear control arms, but I am not 100% sure. Anyway, my question is, what disks and pads should I order? Do they all fit (90 to 01)?
Old Jan 5, 2004 | 10:49 AM
EL Vap133's Avatar
Default Re: Rear disk brakes on 91 hatch (charjacq)
You should use your stock control arms. What year Teg rear brakes did you get? The 90-01 is a large gap.
Old Jan 5, 2004 | 11:04 AM
charjacq's Avatar
New User
Default Re: Rear disk brakes on 91 hatch (EL Vap133)
It doesn't matter which control arms I used. I swapped the whole integra control arm. I'm just inquiring which disks and pad should be used. Are they identical for all years 90-01 or are they different for different generations?
Old Jan 5, 2004 | 11:13 AM
primoEF's Avatar
all 4x100 rear rotors and pads are the same
Old Jan 5, 2004 | 11:24 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charjacq &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't matter which control arms I used. I swapped the whole integra control arm. I'm just inquiring which disks and pad should be used. Are they identical for all years 90-01 or are they different for different generations?</TD></TR></TABLE>
Well in that case you swapped the trailing arms not the control arms.
Old Jan 5, 2004 | 11:28 AM
I Gotta Question's Avatar
Default Re: Rear disk brakes on 91 hatch (primoEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primoEF &raquo;</TD></TR><TR><TD CLASS="quote">all 4x100 rear rotors and pads are the same</TD></TR></TABLE>
lmfao
Old Jan 5, 2004 | 11:42 AM
charjacq's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
Well in that case you swapped the trailing arms not the control arms. </TD></TR></TABLE>
Sorry, my mistake, I did swap the trailing arms, not the control arms. Thank you for correcting me.
Old Jan 5, 2004 | 12:03 PM
EL Vap133's Avatar
Sorry, my mistake, I did swap the trailing arms, not the control arms. Thank you for correcting me.</TD></TR></TABLE>
No problem, I'm here to help...
Old Jan 5, 2004 | 12:10 PM
charjacq's Avatar
New User
I still don't know which disks and pads to order though
Old Jan 5, 2004 | 12:15 PM
are you certain of the year that the conversion is off of if its 94 then pick up some for a 94 whatever year they came off of just get the same year.
Old Jan 5, 2004 | 12:17 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charjacq &raquo;</TD></TR><TR><TD CLASS="quote">I still don't know which disks and pads to order though </TD></TR></TABLE>
To be safe, order the 90-93 pads. Do you know that year Teg the rear disc brakes came off of?
Old Jan 5, 2004 | 01:03 PM
charjacq's Avatar
New User
I was told they were 94+ JDM, but that's all the information I have.
Old Jan 5, 2004 | 01:07 PM
STDClayton's Avatar
if they were jdm they'd be 5-lug...correct???
Old Jan 5, 2004 | 02:02 PM
charjacq's Avatar
New User
Default Re: Rear disk brakes on 91 hatch (seeaclearerskyxx)
Nope, they're 4 lugs.
Old Jan 5, 2004 | 02:20 PM
EL Vap133's Avatar
Hmm, then I would suggest you get 94+ Teg pads. Take yours out first and match them up with the ones you buy.
Old Jan 5, 2004 | 04:44 PM
turbohf's Avatar
all NON-ITR integra/civic/crx's use the same pads in the rear... the ITR/Accord wagon/Prelude VTEC all use a bigger pad...
Old Jan 5, 2004 | 07:43 PM
CRX-RX's Avatar
Actually, Honda/Acura cahnged the compounds used for the different generations and also the 98 got semi metallic pads in an effort to better it's braking distance over previous years. I would imagine the 99-00 si pads are the same as these, but my freind works at acura so I know about those for fact.
Old Jan 5, 2004 | 08:07 PM
pokemon's Avatar
No they wouldn't be 5 lug cause who says it is a Type-R and even then the R didn't come 5 lug up until like 96/97 or around that time cause 96 spec R's had 4x114 patterns on them...Someone please correct me if I am wrong...peaCe and you should be able to use any brake pads for anything other than a type-R as long as it is a Civic or Integra. I would go to the dealer or AutoZone and just check if the part #'s are the same for the 90-93 pads and the 94+ pads...good luck
Old Jan 8, 2004 | 10:21 AM
charjacq's Avatar
New User
Default Re: (pokemon)
For everybody's information, the part numbers for the 90-93 and 94+ disks are the same. The pads part numbers are different, although when compared, they have a very similar shape. The difference is so minimal that they are probably both interchangeable.
pablopab50
Suspension & Brakes
Aug 21, 2013 08:47 PM
elwood
Mar 20, 2004 02:14 PM
