stock ls/greddy dyno #s.....finally......
Old Jan 5, 2004 | 10:30 AM
99lspwr's Avatar
Default stock ls/greddy dyno #s.....finally......
I was getting a little to curious, so I finally got some #s on the car...230whp/217ft lbs. @10 psi of boost, and pump gas.....I ran 12.50 with this exact setup, and 12.06 on 13psi.....I will go back soon with some race gas on 15 psi to see what happens......
Old Jan 5, 2004 | 10:32 AM
Mase's Avatar
Default Re: stock ls/greddy dyno #s.....finally...... (99lspwr)
very nice 1/4 times and traps for such a small turbo. what fuel management?
Old Jan 5, 2004 | 10:36 AM
roydogg's Avatar
Default Re: stock ls/greddy dyno #s.....finally...... (Mase)
Where's the sheet Fockerrr? Can I see ? I beleive franks runnin the hack .
Old Jan 5, 2004 | 10:40 AM
99lspwr's Avatar
Default Re: stock ls/greddy dyno #s.....finally...... (roydogg)
Yup...runnin the hack......I will try to post up the graph tonight...What u dont belive me WTF!! J/K ...I just think its amusing that a few months back import tuner did a turb test on all different cars and turbos, and they said a ls put down 165 whp on 8 psi.....Thats one reason why greddy turbos get such a bad name....BASTARDS!!
Old Jan 5, 2004 | 10:44 AM
roydogg's Avatar
I beleive you . I know whatcha have under the hood . Just wanna see the curves in the dyno sheet.
Old Jan 5, 2004 | 10:52 AM
99lspwr's Avatar
yeah,I know......I will try to get the graphs up later tonight....P.S. come get these damn tires!!
Old Jan 5, 2004 | 11:17 AM
BoostedITR41's Avatar
I made 230whp and 192wtq on the hack with the 18G. I don't know why everyone thinks it is a small turbo it is well capable of 300whp or more. props on the #'s lets see it on race gas
Old Jan 5, 2004 | 11:38 AM
99lspwr's Avatar
Default Re: stock ls/greddy dyno #s.....finally...... (BoostedITR41)
Yeah all my friends in the cool club wont let me in cause of my greddy turbo set-up...You ******* know who u are.....
Old Jan 5, 2004 | 12:09 PM
boostin GSR's Avatar
for the times.. thats amazing.
Old Jan 5, 2004 | 12:14 PM
Rod.'s Avatar
Default Re: stock ls/greddy dyno #s.....finally...... (BoostinGSR)
He his getting 240whp/217ft tq @ 10psi on a greddy kit. I have stock ls also with a t3/t4 50 trim. I am about to get it tuned to 10 psi with hondata s200b. What do you think my range would be. WOuld it be the same??
Old Jan 5, 2004 | 12:44 PM
brianSilverTeg's Avatar
can you list your whole setup in addition to the greddy kit?
Old Jan 5, 2004 | 01:08 PM
DIRep972's Avatar
Smarter than you
not bad at all.
Old Jan 5, 2004 | 01:19 PM
99lspwr's Avatar
Default Re: stock ls/greddy dyno #s.....finally...... (DIRep972)
Setup is a 1994 bone stock b18b,ls trans,stock axles,open diff,off the shelf greddy kit,ur racing crank pulley,aem fpr,safc,440s,in-tank pump,fjo w/b....I guess thats just about it...I am the 1 guy out of 50 people who think the greddy turbo is a good kit...Thats my main point for posting the #s and 1/4 mile times that I do, to show that there are other good kits out the besides the usual....Thanks for the replies.....
Old Jan 5, 2004 | 01:21 PM
99lspwr's Avatar
Oh, I almost forgot the secret weapons. ....Greddy 2 in downpipe,hollowed out cat, hks 2 1/4 cat back....OK, That should be it...
Old Jan 5, 2004 | 01:48 PM
tegasaurus's Avatar
was the 12.06 on slicks? and what was ur 60 ft time... very impressive... i like
Old Jan 5, 2004 | 02:33 PM
99lspwr's Avatar
Default Re: stock ls/greddy dyno #s.....finally...... (tegasaurus)
The 12.06 was on slicks 24x9.2x15 w/ a 1.82 60 ft......Heres the graph BTW....
http://ian.clendaniel.net/gallery/drag/aaw
Old Jan 5, 2004 | 02:40 PM
RedStarGsr's Avatar
NICE!
Old Jan 5, 2004 | 04:28 PM
99lspwr's Avatar
Default Re: (RedStarGsr)
redstargsr::::Thanks for posting the graph!!!As u can tell I am computer illiterate or I would have already posted it up!!Thanks...
Old Jan 5, 2004 | 04:33 PM
tegasaurus's Avatar
Default Re: (99lspwr)
looks good and nice numbers, but its definatly there on the graph that the lil turbo is starting to run outa breath.
damn good times and amazing power
What else could be done do this setup (or similar one) to keep the power still going across rather than starting to drop off?
-ryan
Old Jan 5, 2004 | 04:47 PM
99lspwr's Avatar
Default Re: (tegasaurus)
tegasaurus:::I dont think its the turbo thats lacking the power at that rpm, thats where the power starts to fall on a ls motor..It pulls very hard all the way up to redline and its making max power in the 6300-6400 rpm range...The ls with greddy turbo makes an extremely fun street car though....Did u see how high the torque #s are in the lower rpm band???Sorry b16 guys, but u cant mess with this stump puller...
Old Jan 5, 2004 | 06:51 PM
DENCIO's Avatar
Wow nice torque! I wish I have the same torque on my b16..My b16 only managed 153 ft lb @ 6 psi on 110 octane..
Old Jan 5, 2004 | 06:56 PM
roydogg's Avatar
Runnin pretty rich on the top end huh? A/F ratio looks like a roller coaster . None the less Greddy kit's on LS's are fun to drive except for the dam spiking issues and holding boost at highter rpms and psi .
I'm in the same club as you dogg, I as feel as if I'm a nerd witha 18g turbo cause I don't own a sc61, t3t4, or any turbo bigger than a 18g.
PS: We should both go down to xotic on a suicide mission to see how much these 18g's can make . I'm down to push it to the limit!
Old Jan 5, 2004 | 07:03 PM
roydogg's Avatar
Default Re: (mrdjay107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdjay107 &raquo;</TD></TR><TR><TD CLASS="quote">Wow nice torque! I wish I have the same torque on my b16..My b16 only managed 153 ft lb @ 6 psi on 110 octane..</TD></TR></TABLE>
I was putting out 175 torque at 6-7 psi. Ls's put out alot of torque
Old Jan 5, 2004 | 07:11 PM
kaj's Avatar
kaj
Default Re: (roydogg)
freeing up the exhaust sure would help. when i switched to no cat and 3" dp/full exhaust i noticed a HUGE difference. oh, and a straight-through muffler ( i'm using Magnaflow) i ended up with 226ftlbs or torque out of my B18c
Old Jan 5, 2004 | 07:22 PM
99lspwr's Avatar
Default Re: (kaj)
roydogg:::I think a suicide mission would be fun...I am sure one of us could crack 300 whp, or crack something at least ...As far as the a/f goes, I really did not have too much time to mess with tuning prior to the dyno run, but yeah, I just need to add a little fuel for 4-5 k, and subtract a little from 5-7k...Its all good....All part of the route 9 tuning sessions....
