Help !!....JDM 98 Spec Won't Start
Old Jan 5, 2004 | 10:20 AM
JDM97R's Avatar
Default Help !!....JDM 98 Spec Won't Start
A friend of mine has a problem with he's JDM 98 Spec Itr.
and its a strange one actually................
The damned car won't start
It has an ultra ignition system and a chipped ecu.....
we tried to change the ecu but it still won't start ....
we checked the spark at the spark plugs and it has spark...........
what happened ??
this car used to run perfectly before.......
pls help.
Old Jan 5, 2004 | 10:55 AM
DA6 allmotor R's Avatar
Default Re: Help !!....JDM 98 Spec Won't Start (JDM97R)
it doesn't matter what starter u got. it might just have gone bad because i had the same problem but with a gsr starter not a ultra starter or whatever u got but just change it an see what happens
Old Jan 5, 2004 | 11:07 AM
JDM97R's Avatar
Default Re: Help !!....JDM 98 Spec Won't Start (Da6allmotorr)
I'm sorry but i didn't explain myself well..........
The car is cranking ok......but it still won't start.......
rgds,
Old Jan 5, 2004 | 11:22 AM
R you serious's Avatar
is there gas in the car?
Old Jan 5, 2004 | 11:36 AM
JDM97R's Avatar
Default Re: Help !!....JDM 98 Spec Won't Start (R you serious)
I can hear the fuel pump relay
Old Jan 5, 2004 | 07:48 PM
Kicker773's Avatar
distributor failure??
Old Jan 5, 2004 | 08:16 PM
JjuuN R's Avatar
could be alot of things, does he unplug anything for security reasons? if so have him check it all
Old Jan 6, 2004 | 03:49 AM
Jon D's Avatar
As strange as it sounds if you have two o2 sensors running that could be it. I know that the jdm b18c's only require one o2 sensor.
Old Jan 6, 2004 | 10:06 AM
JDM97R's Avatar
Default Re: Help !!....JDM 98 Spec Won't Start (jh4dc23spoon)
Thanks guys for your help.The car had about 4 lt extra oil in it and the plugs and injectors were all covered with oil.Now it's ok everything back to normal excepr a little white smoke from the exhaust
Thanks for all your help guys
Black-Ty [EG6]
Oct 26, 2014 04:04 PM
EF909
27
Feb 27, 2010 01:30 PM
1baddturbosi
Jul 24, 2007 06:52 PM
civic_976
Oct 21, 2004 06:45 PM
