9mm or 15mm for the OIl Catch Can?
Old Jan 4, 2004 | 09:00 PM
JDM TypeR 307's Avatar
Default 9mm or 15mm for the OIl Catch Can?
What size do I need? or does it make a difference?
Old Jan 4, 2004 | 09:04 PM
Default Re: 9mm or 15mm for the OIl Catch Can? (JDM TypeR 508)
someone would have to know this question!
Old Jan 4, 2004 | 09:08 PM
splitime's Avatar
You don't give any info to work with....
9mm or 15mm what? on where? for what?
Oil catch can? which one? draining? installing?
lines for it?
etc?
Try giving a question with info about your problem, that usually helps.
Old Jan 4, 2004 | 09:14 PM
Default Re: 9mm or 15mm for the OIl Catch Can? (splitime)
Oil Catch can.... like this :
Model: All - HC Oil Catch Tank(Oval)15mm
Model: All - VH Oil Catch Tank (orginal)15mm
Model: All - Universal T-Mounting Bracket
Model: All - HC Oil Catch Tank(Oval)9mm
Model: All - VH Oil Catch Tank (orginal)9mm
IN VTEC's Avatar
9mm is easier to install, otherwise you'll have to step up/down the tube size (or increase the engine nipple sizes to 5/8"/15mm) to accomodate the larger 15mm nipple on the catch can.
15mm is better if you're not recycling the crankcase vapors b/c you can get more volume on the 15mm tube.
Old Jan 4, 2004 | 09:15 PM
Default Re: 9mm or 15mm for the OIl Catch Can? (IN VTEC)
Thanks thats all iw anted to hear... which is easier hehe
Old Jan 4, 2004 | 09:16 PM
and also do i have to get the Universal T-Mounting Bracket
Old Jan 4, 2004 | 09:36 PM
IN VTEC's Avatar
Maybe. It depends on where you don't have room to mount it. THe bracket allows you to get a little more creative with the mounting.
If you're getting one of the newer designs with the nipples on the side, rather than on the top, I'd just set it on top of the EVAP charcoal canister.
Old Jan 4, 2004 | 09:38 PM
someone must answer my queston now!~ i
Old Jan 4, 2004 | 09:41 PM
so I guess UI dont need. I'm gettin the oval one which is the one on the side.... where is that Charcoal thing located?
Old Jan 4, 2004 | 10:20 PM
Two_K Si's Avatar
9mm is the diameter you want. i have a 9mm greddy one in my car. 15mm hose would be too large.
Old Jan 4, 2004 | 10:25 PM
Default Re: 9mm or 15mm for the OIl Catch Can? (Two_K Si)
Do you ahve a mounting bracket
Old Jan 4, 2004 | 10:41 PM
92TypeR's Avatar
FSAE
I use 9mm for my cusco, and they fit perfectly.
Old Jan 4, 2004 | 10:46 PM
Two_K Si's Avatar
yes i purchased the mounting bracket that greddy sells. Like someone above mentioned, the bracket gives you more options in mounting the can. Im sure you could go to home depot and find some hardware if you dont purchase the bracket.
Old Jan 5, 2004 | 11:04 AM
IN VTEC's Avatar
Right in front of the positive terminal of the battery.
EFinSi
Feb 12, 2008 08:20 AM
countryboy
Feb 10, 2005 12:37 PM
gooknom
Mar 17, 2004 10:20 AM
hardboiled egz
Nov 20, 2002 02:55 PM
