power door lock trouble
Old Jan 4, 2004 | 06:54 PM
deviant1's Avatar
Default power door lock trouble
i have aftermarket power door locks with an aftermarket alarm and sometimes when i hit the brakes kinda hard, my doors unlock. they even unlock sometimes if i hit a big bump. they always re-lock though after. anyone know whats going on?
Old Jan 4, 2004 | 07:26 PM
NastyVtec's Avatar
Default Re: power door lock trouble (deviant1)
yes you have a loose ground check it and tighten it..
Old Jan 4, 2004 | 07:35 PM
deviant1's Avatar
Default Re: power door lock trouble (NastyVtec)
ground from what? the brain, locks, siren? etc.....
Old Jan 5, 2004 | 12:15 PM
BrockGrimes's Avatar
Your having problems with the locks locking and unlocking.
It's the wiring for the locks, start a point a and work your way to point b checking all connectors and grounds to make sure they are tight and corrosion free.
That should do it.
Old Jan 5, 2004 | 12:16 PM
=GAME='s Avatar
Default Re: power door lock trouble (BrockGrimes)
re check the wires from the actuators (sp?). a wire might be loose.
Old Jan 5, 2004 | 12:18 PM
92civeg's Avatar
Default Re: power door lock trouble (O.G triple O.G)
its most likely the wiring from the brain to the relay
monicle's Avatar
sounds like someone spared the solder and went with the *shudders* crimp connectors. Always solder that ****.
canucker
Audio / Security / Video
Nov 9, 2008 09:24 AM
boosted civic 2k6
Oct 7, 2005 10:55 PM
Dawightboy
Oct 7, 2002 11:41 AM
