some wierd clutch shit today
Old Jan 4, 2004 | 06:42 PM
91civicEX's Avatar
Default some wierd clutch **** today
ok so i got off work today and didnt wanna drive straight home because my car doesnt warm up all the way when i do that. i took it onto lawrence expressway and cruised in 4th to warm it up. when it got warm i turned around and floored it. 1st gear whent great, i took it to 6500 being conservative. putting it into 2nd was a little tough but i didnt pay too much attention cuz my car does wierd **** sometimes. when i went to put it into 3rd my clutch pedal suddenly lost a lot of pressure but still popped back up. 3rd also ground a little. this i when i got nervous so i let off the gas and pulled into the slow lane. i put it into 4th but only by rev matching. my clutch wouldnt pop back up now. i thought i snapped my cable. well i got lucky on a series of green lights and a well placed parking lot with very little cars. when i went to check the damage all i saw was a very loose clutch cable. being the problem solving genius i am. i tightened it. i really had to tighten it a lot. it went from 1/4 of thread above the nut to about 2 inches. after i tightened it the car made it home alright and the clutch felt a lot smoother. wtf is going on. is this just a case of something popping into place? before my clutch felt stiff and it squeaked. now it feels like my stock one did.
Old Jan 13, 2004 | 10:12 PM
jsplawn's Avatar
Default Re: some wierd clutch **** today (91civicLX)
I had the exact same thing happen to my hatch over on elcamino n saratoga. I just tightened it and it was fine, I eventually pulled the clutch but i couldnt figure out why it suddenly got that extra inch or 2 of slack. I did notice that the pilot bearing return spring was broken on one side but I wasnt sure how that would have caused this. But my car still runs good with no problems since.
Old Jan 14, 2004 | 10:50 AM
slowcarguy's Avatar
Default Re: some wierd clutch **** today (jsplawn)
Sometimes the adjuster sleeve(being all plastic) slides down the threaded part on the cable. It's happened to me before. It only happened once because I swore if it happened again I'd replace the cable all together. It never did it again. Go figure.
~Alex
Old Jan 14, 2004 | 12:17 PM
Outsane's Avatar
Default Re: some wierd clutch **** today (slowcarguy)
I would check under your dash..and see if anything looks different..
95legacy
Sep 24, 2007 09:55 AM
:jdmshmaydm:
Oct 17, 2003 12:27 PM
Mentat Ghola
30
Jul 17, 2003 03:57 PM
USDM 4G VTEC
Jun 20, 2003 05:20 PM
