Anyone do a hyperground sys. w/battery in the back
Old Jan 4, 2004 | 12:20 PM
RuthlessEF-9's Avatar
Default Anyone do a hyperground sys. w/battery in the back
just need to know if its possible if not i guess the idea of putting a hyperground is out of the question
thanks in advance guys
Old Jan 4, 2004 | 12:46 PM
crxgator's Avatar
Default Re: Anyone do a hyperground sys. w/battery in the back (D16z6turbs)
i dont see why you cant do it...i mean just upgrade the stock ground wires and thats pretty much it...
Old Jan 26, 2004 | 12:09 PM
d16nomore's Avatar
Default Re: Anyone do a hyperground sys. w/battery in the back (crxgator)
Yup, it will help. Your engine has gaskets everywhere. They don't conduct electricity very well. By installing a kit, you will clean up the electrical flow in the bay. Your sensors will receive the same source voltage. You will still see an improvement.
I suggest that you not run your ground wires in a loop like HyperGround suggests though. You still get voltage fluctuations at the sensor when you connect it this way. Bring it all back to a central point.
Old Jan 26, 2004 | 12:55 PM
b16_madman's Avatar
Default Re: Anyone do a hyperground sys. w/battery in the back (d16nomore)
so ground everything all back to neg. batt. cable, and/or just a really good frame spot?
Old Jan 26, 2004 | 01:16 PM
green91's Avatar
just to a central spot, make sure you sand the paint off so that you get a good, clean ground spot... and do likewise for the ground spot you use in the back that goes to the battery... id recommend 4gauge from the chassis to battery.. i just used a 4 gauge amp wiring kit and 4 guage -> (2) 8 gauge dist block for the battery relo
justmeandher
19
Mar 12, 2014 05:21 PM
9818tegr
Apr 2, 2009 09:38 PM
The_Todd
Jan 21, 2004 01:55 PM
moridin2004
Audio / Security / Video
Feb 11, 2003 10:01 PM
91sifreak
Apr 18, 2001 07:36 AM
