How often do you need a valve adjustment?
Old Jan 4, 2004 | 11:20 AM
SleepnCiViC's Avatar
Default how often for valve adjustment
how many miles before i need a valve adjustment, im comin up on 30k
Old Jan 4, 2004 | 11:33 AM
py1188's Avatar
Default Re: how often for valve adjustment (SleepnCiViC)
thats a standard interval. Go ahead and do it
Old Jan 4, 2004 | 11:41 AM
k, about how much does the dealler usually run to do this?
Old Jan 4, 2004 | 12:13 PM
strepto's Avatar
Default Re: (SleepnCiViC)
Its really easy! Do it yourself
Old Jan 4, 2004 | 01:04 PM
vtec.dc2's Avatar
depends on how you drive, i do mine every 15K.. if you drive lightly then 30k will do.
Old Jan 4, 2004 | 01:32 PM
ITR.#1446's Avatar
i dont mean to sound like a complete fool but i coming on 60,000 and i dont think the original owner ever did valve adjustment how would i do it myself?
Old Jan 4, 2004 | 01:34 PM
Bbasso's Avatar
Default Re: how often for valve adjustment (ITR.#1446)
Unless you have done it before don't try it on your caR for the first time, Have someone who knows how to do it teach you then attempt it next time.
I do it every 15,ooo miles, and mine is do now...
Old Jan 4, 2004 | 01:35 PM
jdmspoonitr's Avatar
Buy a feeler guage, buy a helms, and buy a new valve cover gasket and honda bond. Follow the instructions. Basically you are checking the clearance of the valves and make sure they all have a uniform gap.
Old Jan 4, 2004 | 02:03 PM
95TEG's Avatar
Default Re: how often for valve adjustment (jdmspoonitr)
So how much might this cost at a dealer or repair shop?
Old Jan 4, 2004 | 03:07 PM
TyPe-R6's Avatar
Default Re: how often for valve adjustment (95TEG)
I do it after every race. The techs at honda tell me to have it done if you go over 8k rpms
Old Jan 4, 2004 | 03:11 PM
Bbasso's Avatar
Default Re: how often for valve adjustment (TyPe-R6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TyPe-R6 &raquo;</TD></TR><TR><TD CLASS="quote">I do it after every race. The techs at honda tell me to have it done if you go over 8k rpms</TD></TR></TABLE>
So what does that meen for most of us, ck and adjust everytime we drive?
Old Jan 4, 2004 | 03:26 PM
mstewar's Avatar
that's not necessary.. 30k is fine, 15k if you beat on it.. any sooner only if you think it was done improperly or there is a problem..
I've seen them for anywhere from $40 to $80 at the stealership.. varies a bit..
Old Mar 18, 2004 | 12:07 PM
itr1244's Avatar
sorry to bring up old topic but i was just wondering what happens if i NEVER did valve adj? for 70000 km
is my R in danger?
Old Mar 18, 2004 | 12:09 PM
Bbasso's Avatar
Default Re: how often for valve adjustment (itr1244)
I would think not, but your definitely loosing some power.
Old Mar 18, 2004 | 12:12 PM
DsITR's Avatar
Just incase someone stumbles on this topic. Here is a decent write up
http://www.c-speedracing.com/h...t.php
Old Mar 18, 2004 | 01:22 PM
nsxtasy's Avatar
H-T Order of Merit
The '98 service manual says to do this every 30K miles (48K km) or 24 months, whichever comes first.
Old Mar 18, 2004 | 07:26 PM
thad
Guest
Posts: n/a
Default Re: how often for valve adjustment (nsxtasy)
i'd only worry about it if you've reved it really high on too many ocassions or if you have the valves out or changed anything in the valvetrain
Old Mar 18, 2004 | 07:34 PM
ITR#132's Avatar
I find that checking it frequently; You dont have to adjust too many, only the couple that are out of spec.
I check mine approx. every 10k miles. And you can reuse all the gaskets. Most of the times I didnt use Hondabond either.
Old Mar 18, 2004 | 10:55 PM
itr1244's Avatar
Default Re: (ITR#132)
ok. thanks guys
i should try to do it soon
minitec
12
Jun 12, 2003 02:43 AM
RuskeR
May 16, 2003 10:39 AM
laNk_LinK
Mar 3, 2003 03:27 AM
GreenMachine
Jan 14, 2002 04:01 PM
