wiring harness
I think, the engine harness stays the same. You just have to get the subharness conversion for the ecu. There is much more for the OBD1 conversion. I suggest you read search and read up.
What are you trying to convert from/and to?
Hasport makes an OBD0 DX-MPFI or an OBD0 DX to VTEC harness. But if you want it to be used on an OBD1 engine. There are some more things you need to add and things you need to do.
bobbyisking
Jul 7, 2008 09:22 AM
