C/V joint/ whole axle. which is easier?
I keep on getting a clicking sound whenever I turn my steering wheel. Buddy said it was the CV joints. Since both are going bad would it be easier to replace the whole axle assembly or just replace the CV joints? Also looking for the most cost effective way to do this.
You have to remove axle to repair the joints and it is quicker to just replace the axle therefore making it more cost effective. Time is money in some instances.
Its reallyy much easier to remove the whole axle and have it replaced with a rebuilt one. Make sure to call around and see who's price is cheapest, and who has a warranty.
Some places have no warranty, some places have lifetime... and you should pay anywhere from $49.95 to $99.95.
Also, some places offer a core return if you give them your old axle. I had to replace the boot on mine (the joint was still fine) and it ended up being easier and cheaper to replace the whole axle since I didn't want a cheap "clam shell" boot. Pep Boys is your friend for rebuild parts.
Watch with PepBoys if you have an Si. They always try to sell me DX axels because they will fit. I honestly don't know if there are many differences, but the axels that they have tried to sell me in the past have a smaller looking CV joint than my Si (orange stripe) axels. The spline fits, but the cup looks smaller. Advance auto is the only place that I've found that acknowledges the stipes on the axel and sells you an orange stripe for an Si.
That being said, do the whole axel. You can literally do it in under an hour and keep your hands relatively clean.
They probably tried to sell you HF shaft which are smaller then SI/DX axles. SI and DX use the same exact axles. And do the whole axle time is money
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">They probably tried to sell you HF shaft which are smaller then SI/DX axles. SI and DX use the same exact axles. And do the whole axle time is money</TD></TR></TABLE>
I'm not 100% sure. The spline fit fine so I don't think it was an HF or STD, but the actual axel was smaller and the CV joint cup was smaller. Various locations have done this to me so I finally stopped going there.
EDIT: Actually, I just looked on hondaautomotiveparts.com, and they list different part numbers for DX and Si axels and outer CV joints. The inner joints are obviously the same, but according that site, and according to what my experiences have been, the Si and DX do use different, but compatible axels. The DX ones fit, but they look smaller. I think those are the pink stripe axels. All of the Si's I've purchased are the orange stripe axels, and the HF I think uses a green stripe.
I really am only going by limited sources... Basically hondaautomotiveparts, Advance auto, and what I've seen over the years... Is there anyone that knows for sure what the story is on axels.... not what will fit, but what actually belongs in there? I'm thinking...
Si: orange
Dx: pink
STD/HF: green
So I'm standing by my original claim that pep boys should be avoided because you will likly come out of there with the smaller DX axel instead of the Si axel. Advance, in the past anyhow, asks you what color stripe is on your axel and replaces is as such.
Modified by therealciviczc at 4:00 PM 1/5/2004
Si: orange
Dx: pink
STD/HF: green
All the chain stores sell aftermarket axles. None of then have the rubber balancer like OEM do. Look in the phonebook for an axle shop. Call around and see who specializes in rebuilding them. I can get both OEM axles rebuilt for under 100 bucks.
No doubt about it... Change the axels. Local auto parts stores all get the same quality refurbed' axels so anywhere will do. Best price is the way to go when getting them. Change your transmission fluid while you are at it. Very important in the life and smoothness of your tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDawwg6969 »</TD></TR><TR><TD CLASS="quote">How many splines are on the STD?
STD = 23 outer splines
DX/Si = 26 outer splines
ShinotakuX
26
Oct 18, 2008 06:38 PM
