wilwood caliper questions
Old Jan 4, 2004 | 07:06 AM
Sliced Beard's Avatar
Default wilwood caliper questions
does wilwood make a caliper that fits directly onto the stock location on a 94-01 integra but still uses stock rotors.
i just want to upgrade calipers without upgrading rotors because of $ and i really dont think there is a need when my car stops and decelerates like crazy now all i want is a better caliper
thanks in advance
also if you can find them where would a good place to buy them be and if you find any part numbers those would be helpful
i have checked fastbrakes and summit and all they have is big rotor kits
Modified by dirtyd463 at 11:38 AM 1/4/2004
Old Jan 4, 2004 | 07:26 AM
MTP04's Avatar
Default Re: wilwood caliper questions (dirtyd463)
I think they do. I think its for the gsr brakes/rotor size. I am sure someone else will confirm this.
Old Jan 4, 2004 | 03:58 PM
Default Re: wilwood caliper questions (MTP04)
there has to be someone that knows
Old Jan 4, 2004 | 04:05 PM
StyleTEG's Avatar
Why do you want more clamping force if your car already stops adequately?
Old Jan 4, 2004 | 04:17 PM
Default Re: wilwood caliper questions (StyleTEG)
i would like them to stop a little better than they do now but i dont think it is necessary to go larger with the rotors
Old Jan 5, 2004 | 08:38 AM
i am still wondering if they are made
i have emailed wilwood but no replies as of yet
Old Jan 5, 2004 | 08:45 AM
StyleTEG's Avatar
I have not herd of any larger caliper that uses the stock rotors. (minus the ITR rotors).
You are better off getting a really high quality pad, which increases brake torque.
brake torque is (Disc radius * clamping force * coefficient of friction) / 12
so the CF of the pad can make a large difference.
Old Jan 5, 2004 | 03:04 PM
ok thanks for the good info
maybe some carbotech or some ebc reds will do
Old Jan 7, 2004 | 07:20 AM
CRX T-Si's Avatar
The purpose of the bigger rotor is to dissapate the heat so the rotors do not warp so easy.
I have big GS-R calipers(stock pads) and 10.3 rotors on my CRX utilizing the 91 EX knuckle with rear disc brakes.
That thing stops on a dime but the rotors warp after a few months so I really do not see the point in just changing just the caliper without the bigger rotor.
Kind of reverse science. If you want to stop better then what you got then I would go for a bigger rotor using the stock caliper.
Also you should get some better brake pads then stock like Axxis brake pads. This is good for street use.
http://www.cobaltfriction.com/...a.htm
Old Jan 10, 2004 | 05:34 PM
Default Re: wilwood caliper questions (CRX T-Si)
well im not too worried about warped rotors
just wheel compatibility
i have no problen going out and buying new rotors every few months
hell they only cost like 19 bux a piece at autozone
LANEVOIX
Jun 23, 2005 04:37 AM
Buckshot
Feb 3, 2003 06:54 PM
Vampyre
Dec 25, 2002 08:31 PM
Veil_Side_
Jun 29, 2002 11:07 AM
shamoo
25
May 31, 2002 09:54 PM
